R32 6.5 inch Spacer
Hello,
This is my review of some audio upgrades that I made to my 1990 Nissan Skyline R32 GTR that I thought I would share with the rest of you guys! In particular, I am reviewing some custom 6.5 inch speaker adapters for those awful 4x6 speakers in the front from carstereoadapters.com.
When I purchased my car the rear 6.5 inch speakers did not even work and emitted no sound. The front speakers were in horrendous condition as well. There was zero bass and so much distortion that I knew these were just going to be thrown away.
My initial thoughts were to just to replace whatever speakers were in the car with the same sized ones as I felt like it would be too much work to custom build an adapter. There was no kit readily available for these cars and the door cards did not offer too much space to clear the windows so I thought it would be a waste. My friend told me to contact Patrick Henry at www.carstereoadapters.com and we talked about creating some custom brackets that would fit in the car. So we found some rough schematics and I decided to be a guinea pig for the project for the rest of you guys so that others could easily upgrade their audio systems without having to build their own or scour the internet for schematics. Also, I felt that I wanted to upgrade the stock stereo system as much as possible because I did not want to install 4x6 speakers and then decide to change to bigger speakers down the road. So they took the template and created a one off set of adapters and told me that they would keep revising them until the fitment was absolutely perfect for the final application.
I decided to go with 4 Polk DB651’s to keep the same brand and model across the entire car. The rears were relatively easy to install as the 6.5’s went in with no problems or modification in the stock speaker locations. Unsurprisingly, the rear speakers were completely destroyed. The speaker surrounds were completely disintegrated and missing. Also, the paper cones were torn and flaked off to the touch. This is what twenty six years of wear would do to the OEM Speakers.
The fronts took a little more time due to the amount of cutting and Dynamatting I had to do, but luckily these cars have pretty rectangular doors that made cutting the rolls of Dynamat easier. Also, the OEM sound deadening in the car was pretty abysmal as they only use a plastic bag that they glue onto the doors. The Dynamat really helped to decrease cabin noise and it also gave the doors a nicer and more solid thud when you close the doors after they were installed.
The front speakers were in terrible condition as well just due to age. The surrounds had also completely disintegrated like the rears, but the overall cones of the front speakers were still intact. The schematics that I had found for the Car Stereo Adapter (CSA) guys had missing values for the actual mounting points, but they did their best to guess where to drill the recessed holes and some values actually came out pretty close. I had the option of measuring them and sending them back to the CSA guys then they would send me back perfect ones, but being the impatient car enthusiast that I am I wanted to have the car finished ASAP and that no one could see the holes with the speaker grills anyway.
I decided that I would drill the correct sized holes and send back the OEM brackets for them to use for R&D to create an accurate adapter that would be ready straight out of the box. The quality of the material they used was very good and I decided to paint the adapters black for a more stealthy appearance. Upon initial test fitment both windows rolled down clearing the larger speakers easily and the door cards fit back in place perfectly over the adapter and extra Dynamat underneath it.
These adapters should be made available to the public very shortly so stay tuned!
My Car:
5D978319-44A7-4B12-AAC3-4EC53A05AF53_zps
Rear 6.5's completely destroyed:
02799B6C-81FD-4521-95EF-DE447BB9A554_zps
Old door panel/4x6 speaker:
03BF8011-31B5-4227-A113-1735D963CAB9_zps
Front 4x6 Speakers mostly destroyed:
01999AA9-3BE5-4294-9590-ECB38BC25509_zps
Passenger door:
933AC40E-59CC-4B85-968B-3B5F4CCD6907_zps
Old vs. New:
5DAD98C1-5BC0-4C21-A5C9-927D81A8BC44_zps
Drivers Door:
C3F3980A-518B-48E7-A878-7B396B9D35E7_zps
Installed:
DA3508D3-3D91-47C1-99BD-B77AF0022770_zps
  • Like 1
https://www.sau.com.au/forums/topic/468884-r32-65-inch-spacer/
  • 1 month later...
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
