Clutch not disengaging
Hey guys!
So story goes.... I have an rb25 s14 been driving for about 2 weeks. Clutch is an excedy 5 puc and was opperating properly!
last week my clutch engagement point started to lower and eventually I was pumping the clutch between shifts!
In the end got the car onto drive way and lost all clutch. Decided to replace master and carried out full system bleed.
I should also point out I used the pushrods from the old master thinking my geometry would be g2g...... But no!
Went back over it all a second time and Confirmed bleed is good slave has over 3/4 inch throw pivot ball is good and fork doesnt look bent. Clutch wont disengage..... im confused!
Went to pedal adjustment but have now loaded the slave rod onto the fork and still don't have enough throw to disengage clutch!
PLEASE SOMEONE HELP! Before I pull the box for no good reason haha
https://www.sau.com.au/forums/topic/468889-clutch-not-disengaging/
As above. Looks like your going to have to remove box to find out. I was in this position once and was also reluctant to remove box , when I finally did and starting unbolting the pressure plate, it rained broken clutch plate on me. I guess it didn't like 2nd gear burn outs.
  • Like 2
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
