R33 tune now no a/c
So I've had a good search around and can't find much info on this. Basically i had my car tuned 2 weeks ago and it seems that the tune or whatever has been done has stopped my a/c from working. Could this be true? I had a auto elec have a look and he checked everything! and was confused as to way the compressor would not kick in unless it was earthed and the gas was spot on. I told him that its running a aftermarket ecu (powerfc) and he suggested that something could be wrong and it seems to be ecu related. I did a sensor check and its showing 0v Could it be something related to the powerfc?
https://www.sau.com.au/forums/topic/468892-r33-tune-now-no-ac/
Im not familiar with the software for power fc and not sure if the ac could be disabled from there, maybe someone else can chime in there but when I had a similar issue with my ac compressor not kicking in, it turned out to be the thermistor which is a temp sensor that sits in the ac core and tells the compressor when to turn on and off. Was just a bad contact on the plug. cleaned it, put it back together and has been fine since. This particular plug can be accessed by removing the glove box and backing plate, it is mounted to the top left of the white box, Its a bit tight but reachable. Should only take 5-10 mins to get to it and check.  As far as the ecu goes, maybe give your tuner a quick call and ask.
  • Like 1
I dont recall a setting to turn off the AC on fc edit. There are settings for idle when AC is on or off but that's about all i remember.
Go into sensor/sw check on your hand controller and watch the AC and ACR dots. I think (and I could be wrong) that one indicates the AC unit is turned on and the other should come on when the compressor kicks in. (On is black dot off is white dot)
Had my tuner hook his laptop up and we had a look around. The only option to do with a/c was revs when its turned on. Had a play around today with a test night on the ecu when i tried pin 9 (ac relay) the compressor fired straight up. Waiting to try another thermistor
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
