Garage Sale R32 GTR RB26 (ECU, Fuel Rail, Injectors, AFM, AFR Gauge, Intercooler, Brakes)
Hey guys,
Got a few parts that became spares after upgrades. Located south west Sydney and would prefer pickup. If postage necessary, it'll be at buyers expense.
320kw package - $1000 for everything
  • Apexi Power FC with hand controller tuned on 98ULP - $450
  • Standard fuel rail with Sard 700cc injectors - $250
  • 2 x Z32 AFM with Tomei plugs - $350
  • Standard RB26 exhaust manifolds - $100
  • Standard RB26 dump pipes - $100
Brand new AEM Uego AFR meter (rrp $300) - $200
Mines ECU could probably use for the case - $50
A-pillar twin gauge holder (suit R32) - $100
Golpher china spec alloy radiator - $40
Standard RB26 intercooler - $100
Standard RB26 twin turbo pipe - $50
Standard RB26 front brake package - $300 for everything
  • Calipers (unknown pads) - $200
  • Rotors standard size (unknown brand) - $100
  • BM50 brake master cylinder - $100
Happy to hear offers. Just want to see it gone really.
Thanks,
Slav
7 minutes ago, justjoshinyam8 said:
Details on radiator?
China spec alloy. Pretty sure it's the same thickness as stock.
1 hour ago, Dave76 said:
Would you take $150 for the air fuel gauge where are you located at
Sorry mate. Sold pending payment.
Updated list:
  • Apexi Power FC with hand controller tuned on 98ULP - SOLD PENDING PAYMENT
  • 2 x Z32 AFM with Tomei plugs - SOLD PENDING PAYMENT
    Brand new AEM Uego AFR meter (rrp $300) - SOLD PENDING PAYMENT
  • Mines ECU could probably use for the case - $50
  • A-pillar twin gauge holder (suit R32) - SOLD PENDING PAYMENT
  • Golpher china spec alloy radiator - SOLD PENDING PAYMENT
  • Standard RB26 intercooler - $100
  • Standard RB26 twin turbo pipe - $50
  • 3 months later...
Updated list:
  • Calipers (unknown pads) - SOLD
  • Rotors standard size (unknown brand) - SOLD
  • BM50 brake master cylinder - SOLD
