Hi guys,
Been rebuilding my Midnight Purple SII R33 over the past year and thought I'd share my powdercoating experience.
Had some rough looking 18" rims that had been previously spray painted black.
So looked at new 19" and $$ out of my range atm until my car exits the panel shop.
So decided to powder coat the 18" white.
Went about getting them sandblasted back to bare metal up at Tullamarine.
Then got our powder coaters to recoat them PEARL WHITE.
They look really great and well worth $$ if looking to refresh older rims.
Added some carbon fibre caps and they look fine as a cheaper option whilst saving up for some Japanese rims Work/Volk/Enkei.
Some photos of the finished product below :
IMG_1486250470.469090.jpg.bc536faac1f875IMG_1486250483.935562.thumb.jpg.567f1cefIMG_1486250499.785026.thumb.jpg.81d6d4e7
  • Like 2
https://www.sau.com.au/forums/topic/468939-powdercoated-rims-a-good-option/
Sandblasting was approx $40 - $50 per rim. Again depends on work required. But you need to remove anything plastic and weights from each rim beforehand. These had little plastic inserts stuck in with double sided tape which took me 2hrs to remove which was annoying.
Powdercoating is usually approx $450 for 4 Rims. But I got it done cheaper as our workplace gets work through them on a regular basis.
All depends on what colour you want and rim size.
Approx $50 for new centre caps.
They look brand new again!
Mainly did it because I like the huge dish on these rims.
18x7.5 front
18x8.5 rear
5 hours ago, V28VX37 said:
Looks good mate, what kind of price was is all up, roughly?
It's usually around $100 per wheel for sandblasting and coating.
Check out dulux powdercoat for a small selection of colours.
Those wheels turned out amazing!
Got the Sandblasting done at Chandler Engineering, Tullamarine.
Powder coating done at Top Cote , Airport West.
Both great places. And both places know each other.
Definitely recommend both businesses.
Nice blokes.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
