I use Motul 300V and unlike apparently most of you I change it after 20,000km (including track days). I have sent samples for oil analysis and the results have suggested there is no reason to change it more often.
Kiwi, over what time frame is the 20k done. oil companies used to tell us oil loses its viscosity after 6 months, now with synthetic they say 12. Wondering if your analysis proves it can keep for longer.
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7809783
31 minutes ago, MrStabby said:
I like that you dont throw away expensive oil that's in good condition. There should be more of this good sense.
See the attached. The Oil may be in "good condition" but its only good for the intended application which is track days. The data sheet on Motuls website states 300v is intended for track-GT-Rally (short distance race) use. This in my opinion would mean it provides worse protection than conventional fully synthetic oils (i.e. castrol, penrite or even motul 8100) on road use. Thats just my theory anyway based on the technical data sheet.
track days = 300v --> Fully synthetic
Road use = Everything else --> 300v
300V_Trophy_0W-40_(GB).pdf
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7809794
  • 7 months later...
Since it's not mentioned, I just like to add that 15W50 is one of the most popular oil viscosity choice among GT-R owners around the world. I even remember in GTROC U.K, there was a poll back then, 15W50 came on top, followed by 10W60. GT-R's RB26 is high revving so they like these kinds of "thick" oil. Nismo in fact, has these oils recommended for the RB26. Nismo competition oil 15W50 and Nismo RB26 oil 10W60. The 10W60 is more of the street / track performance one, while the 15W50 is more like the 300V, a race oil.
Also an Evo (CT9A) driver here, and I can tell, these boys has different taste when it come to their oil. :10_wink:
Here's the Nismo 10W60 RB26 oil BTW.
Edited by GodziRRa
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7852524
Its like a competition to see who can spend the most on engine oil.  If it is synthetic it will be more than good enough.  When the RB26 came out (Back in the olden days - 1989) Nissan only ever recommended a semi synthetic oil.  The worst synthetic you can buy now is going to be much better than that.
But yeah spend up on pretty coloured boxes and marketing.  Or just buy what's on special.
As an aside Penrite promises to have loads on zinc in it which is no bad thing.
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7852567
Yup, it’s different strokes for different folks, people will believe what they wanna. But I must disagree it’s just about those pretty packages. Remember, those old Porsches, Ferraris, etc. are also not into pure synthetics back in the day. But nowadays, that’s what they recommend for their old models too. Oil technology have gone very far now, anything that gives optimum performance, and will prolonging engine life will be the one recommended.
I agree with mick, "ya pay for quality". Because at the end of the day, better quality = more cost. As the saying goes, and this is a car enthusiast favorite, you get what you paid for. ?
Edited by GodziRRa
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7852649
I ran Mobil 1 full syn 10W-40 or whatever in my old RB20DET, engine became noisier after about 3,000km of daily driving. Dumped it and put Penrite HPR10, was quiet ever since, and saved myself $20 a bottle. Engine is still going in another car I believe.
So yeah, marketing.
https://www.sau.com.au/forums/topic/468940-oil-rb26/page/2/#findComment-7852715
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
