R32 from thailand
Hi everyone,
I'm Liam originally from Perth but now in Phuket Thailand, just bought my dream car after years of searching for one in good nick, 1992 r32 GTR all original apart from 5zigen exhaust, and plan to keep it unmodified, just love the way it drives with no mods.
I drove it from Bangkok to my home in Phuket, everything was sweet apart from a minor misfire on boost, I was just going to clean up the coil packs, but figured a 25 odd year old car, wouldn't hurt putting new coils, plugs, and harness in, so I'm currently ordering the parts.
I also noticed the coolant starts boiling after shutting it down, so going to flush the cooling system and bleed it properly.
apart from them, it's an absolutely awesome car!
  • Like 2
https://www.sau.com.au/forums/topic/468946-r32-from-thailand/
Nice! Wouldn't see many of those around on the road from Bangkok to Phuket I'm guessing?
Fingers crossed it's just air in the system. I had the same last year, diagnosed as a blown head gasket, replaced at a great cost. Then a last month the same symptoms again and the bottom end went, now looking for a replacement engine...
Yeah, and it's crazy the amount of attention it gets from tourists from countries without skylines!
once I'm back home I'll check over the cooling system, the only 2 faults are the ones I didn't notice before purchasing it, either way, I would have bought it due to how rare they are in Thailand.
looks lovley,
....a missfire on boost and boiling coolant raises a few red flags, i would suspect the head. just get it looked at before driving allot. are you on your own with mechanical stuff? are their any capable workshops?
Edited by GH05T
thanks, it's a beautiful car.
personally I believe it's 2 unrelated problems, I also just realised I tested out the heater on the drive back after the a/c heater controller was replaced, heaters never get used in Thailand, so I am pretty sure it's an air pocket.
there is no specialty workshops that I am aware of in Phuket, good thing I'm a mechanic ;-)
  • 1 month later...
Coils, spark plugs, and new harness has fixed the misfire, new radiator cap has stopped the coolant from boiling.
doesnt miss a beat now!
had a closer look around the car, it has a mine's ecu, hks intercooler piping, Cusco master cylinder stopper, adjustable coilovers, original boost restrictor is in place.
these parts all seem to be early 90's period parts, e.g. The hks pipes are bulky cast aluminium rather than the more modern pressed aluminium piping.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
