R32 from thailand
Hi everyone,
I'm Liam originally from Perth but now in Phuket Thailand, just bought my dream car after years of searching for one in good nick, 1992 r32 GTR all original apart from 5zigen exhaust, and plan to keep it unmodified, just love the way it drives with no mods.
I drove it from Bangkok to my home in Phuket, everything was sweet apart from a minor misfire on boost, I was just going to clean up the coil packs, but figured a 25 odd year old car, wouldn't hurt putting new coils, plugs, and harness in, so I'm currently ordering the parts.
I also noticed the coolant starts boiling after shutting it down, so going to flush the cooling system and bleed it properly.
apart from them, it's an absolutely awesome car!
  • Like 2
https://www.sau.com.au/forums/topic/468946-r32-from-thailand/
Nice! Wouldn't see many of those around on the road from Bangkok to Phuket I'm guessing?
Fingers crossed it's just air in the system. I had the same last year, diagnosed as a blown head gasket, replaced at a great cost. Then a last month the same symptoms again and the bottom end went, now looking for a replacement engine...
Yeah, and it's crazy the amount of attention it gets from tourists from countries without skylines!
once I'm back home I'll check over the cooling system, the only 2 faults are the ones I didn't notice before purchasing it, either way, I would have bought it due to how rare they are in Thailand.
looks lovley,
....a missfire on boost and boiling coolant raises a few red flags, i would suspect the head. just get it looked at before driving allot. are you on your own with mechanical stuff? are their any capable workshops?
Edited by GH05T
thanks, it's a beautiful car.
personally I believe it's 2 unrelated problems, I also just realised I tested out the heater on the drive back after the a/c heater controller was replaced, heaters never get used in Thailand, so I am pretty sure it's an air pocket.
there is no specialty workshops that I am aware of in Phuket, good thing I'm a mechanic ;-)
  • 1 month later...
Coils, spark plugs, and new harness has fixed the misfire, new radiator cap has stopped the coolant from boiling.
doesnt miss a beat now!
had a closer look around the car, it has a mine's ecu, hks intercooler piping, Cusco master cylinder stopper, adjustable coilovers, original boost restrictor is in place.
these parts all seem to be early 90's period parts, e.g. The hks pipes are bulky cast aluminium rather than the more modern pressed aluminium piping.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
