R33 GTR from Alaska
Tzuteng
 Share
R33 GTR from Alaska
New member here. Been lurking the forums for some time researching about a lot of stuff regarding the rb26 platform and the BCNR33 chassis. Currently stationed in Alaska. I have an r33 gtr on the way from Washington. It's damn difficult to get a skyline here in the US, so when I was presented the opportunity I jumped on it without thinking it twice.
Anyways, happy to be part of the forum.
  • Like 2
On 2/11/2017 at 5:01 PM, squareznboxez said:
Welcome mate, post up the specs, mods and pics when you have a chance.
Wealth of info on BCNR33's on this forum as they are a great value buy in Aus.
Will do. Its completely stock for except an HKS exhaust and some bbs rims. The car has less than 55k kms.
4 hours ago, niZmO_Man said:
Nismo meter...
Also the engine bay looks like it experienced something... messy.
Seats and body look good though!
Messy as in dirty? And what about the Nismo meter? You say it like its something bad.
Edit: I thought those came from stock. Just googled r33 gtr cluster and noticed the difference.
Edited by Tzuteng
Ya Nismo meter means swap, so kms will be lower than actual (unless dealer fitted, which would be awesome).
Engine bay does look dirty, almost like a radiator hose split (and wasn't cleaned up properly). But of course could be just dirt. Random coloured coilpack and timing gears cover too. I know I'm nit picking, but people should be wary of things like low km before trying to extract more performance out of them (instead of modding a "low km" dodgy import, breaking something, then declaring imports as shit).
I'd always sus out the low mileage on imports, but hey, if the rest of the car is fine, then it's a good buy ;) . Great effort on getting one though, I heard they are super hard to attain over there. You shouldn't have electrical issues like the R32 can have :)
  • Like 1
Thanks for the info. Make sense now. Yeah they are very hard to find, especially without too many mods which I am very picky about. The previous owner brought it from Japan when he was stationed there. The first thing I am going to do is compression test and inspection of everything in the motor. I know the water pump, timing belt and intake/exhaust and valve cover gaskets were replaced with OEM Nissan parts. Not planning power modding for the moment.
Is there a way to confirm actual vehicle mileage?
I am open for advice so keep em coming.
Try this:
http://www.japanesehistorycheck.com/
They should give a run down of the auction sheet (if they can get the history of your car).
But I tend to ignore kms (unless the car has properly filled log books, then I know its service history) and assume the car will need a major service. Condition of body, mechanical, electrical, etc components. is more important than the odo numbers to me.
It sounds like the car was well looked after, so you shouldn't have any major issues :thumbsup:
  • Like 1
7 hours ago, niZmO_Man said:
Try this:
Ran two reports on the vehicle and have on hand auction sheets and reports regarding the vehicle. After researching I found out that the cluster was indeed replaced. The auction sheets use symbols like $ and #  and explanation to indicate the discrepancy on the mileage. For example, in my case there was a discrepancy on the mileage so beside it in the report it had a $, which means the odometer was replaced legitimately. I, however, have more luck understanding a martian than what it says in the report. If anyone can translate these japanese reports I will really appreciate it.
Also, thanks for the info and the heads up Nizmo Man.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
