R33 GTR from Alaska
New member here. Been lurking the forums for some time researching about a lot of stuff regarding the rb26 platform and the BCNR33 chassis. Currently stationed in Alaska. I have an r33 gtr on the way from Washington. It's damn difficult to get a skyline here in the US, so when I was presented the opportunity I jumped on it without thinking it twice.
Anyways, happy to be part of the forum.
  • Like 2
https://www.sau.com.au/forums/topic/469019-r33-gtr-from-alaska/
On 2/11/2017 at 5:01 PM, squareznboxez said:
Welcome mate, post up the specs, mods and pics when you have a chance.
Wealth of info on BCNR33's on this forum as they are a great value buy in Aus.
Will do. Its completely stock for except an HKS exhaust and some bbs rims. The car has less than 55k kms.
4 hours ago, niZmO_Man said:
Nismo meter...
Also the engine bay looks like it experienced something... messy.
Seats and body look good though!
Messy as in dirty? And what about the Nismo meter? You say it like its something bad.
Edit: I thought those came from stock. Just googled r33 gtr cluster and noticed the difference.
Edited by Tzuteng
Ya Nismo meter means swap, so kms will be lower than actual (unless dealer fitted, which would be awesome).
Engine bay does look dirty, almost like a radiator hose split (and wasn't cleaned up properly). But of course could be just dirt. Random coloured coilpack and timing gears cover too. I know I'm nit picking, but people should be wary of things like low km before trying to extract more performance out of them (instead of modding a "low km" dodgy import, breaking something, then declaring imports as shit).
I'd always sus out the low mileage on imports, but hey, if the rest of the car is fine, then it's a good buy ;) . Great effort on getting one though, I heard they are super hard to attain over there. You shouldn't have electrical issues like the R32 can have :)
  • Like 1
Thanks for the info. Make sense now. Yeah they are very hard to find, especially without too many mods which I am very picky about. The previous owner brought it from Japan when he was stationed there. The first thing I am going to do is compression test and inspection of everything in the motor. I know the water pump, timing belt and intake/exhaust and valve cover gaskets were replaced with OEM Nissan parts. Not planning power modding for the moment.
Is there a way to confirm actual vehicle mileage?
I am open for advice so keep em coming.
Try this:
http://www.japanesehistorycheck.com/
They should give a run down of the auction sheet (if they can get the history of your car).
But I tend to ignore kms (unless the car has properly filled log books, then I know its service history) and assume the car will need a major service. Condition of body, mechanical, electrical, etc components. is more important than the odo numbers to me.
It sounds like the car was well looked after, so you shouldn't have any major issues :thumbsup:
  • Like 1
7 hours ago, niZmO_Man said:
Try this:
Ran two reports on the vehicle and have on hand auction sheets and reports regarding the vehicle. After researching I found out that the cluster was indeed replaced. The auction sheets use symbols like $ and #ย  and explanation to indicate the discrepancy on the mileage. For example, in my case there was a discrepancy on the mileage so beside it in the report it had a $, which means the odometer was replaced legitimately. I, however, have more luck understanding a martian than what it says in the report. If anyone can translate these japanese reports I will really appreciate it.
Also, thanks for the info and the heads up Nizmo Man.
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
