Hello from the Great White North
Hey guys & gals... just dropping a note to say hello. Been an avid reader for awhile now.
Thought it would be best to join and participate when and where I can.
She's a MY99 R34 GTT in white, and it sure is a blast to drive.
Happy Motoring everyone...
Cheers
  • Like 2
https://www.sau.com.au/forums/topic/469020-hello-from-the-great-white-north/
Thanks guys...
As for mods, I have it fairly conservative. CAI, HKS cat back exhaust, HSD MonoPro coilovers (desperately needed new ones as the OEM coilovers were pretty soft), I rust proofed the doors for piece of mind, DRL relay and rear red LED marker lites (I had to for it to pass inspection) and running MPSS tires. When the car came over it had the 'standard' Japan side window vents, but I removed those right away, as both were cracked badly.
Not planning to get much more crazier than that, it's a great DD with just over 86k km's on the clock.
What I do need to do, is to find or make something to cover the front licence plate area.
Cheers
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
