El_Mutto Posted February 11, 2017 Share Posted February 11, 2017 R32 gtr clutch probelm Hi guys. I've got some problems with my clutch. I keep getting air in the system. I've bled it 3 times and each time after about a day I can no longer select a gear. I've checked around the clutch master and inside the cabin and found that there is no liquid leaking. The only known problem that I know of is that the vacuum booster popped a while back but I have plugged up the tube so it doesn't make that air noise every time I press the clutch. My question is that I've driven the car around for around 4 months with no vacuum booster without any trouble and now I keep losing the clutch. Could the vacuum booster be the problem or is it something else like the master or slave cylinder? Link to comment https://www.sau.com.au/forums/topic/469023-r32-gtr-clutch-probelm/ Share on other sites More sharing options...
niZmO_Man Posted February 11, 2017 Share Posted February 11, 2017 Do you have the standard rubber hose? Link to comment https://www.sau.com.au/forums/topic/469023-r32-gtr-clutch-probelm/#findComment-7810596 Share on other sites More sharing options...
El_Mutto Posted February 11, 2017 Author Share Posted February 11, 2017 Yes. Link to comment https://www.sau.com.au/forums/topic/469023-r32-gtr-clutch-probelm/#findComment-7810605 Share on other sites More sharing options...
