rb26 rebuilt engine with exceptional attention to detail
Hi,
I've had my r33 rb26 engine totally rebuilt including head.
Unlike many rebuilds, nothing has remained untouched and all screws, metal parts, springs have been cleaned, polished, electrocoated.
Some components have been sandblasted and painted or powder coated.
All machining work performed by orger who worked on the r32s that ran in the v8 championships.
New end spring plastic brackets were machined for throttle bodies.
The motor has not been started and sits in a RWD 300zx.
The project has blown out and while in no rush, I'm considering selling and SEEKING EXPRESSIONS OF INTEREST.
Engine owes me over 30k, so will say asking for 30 and open to reasonable offers.
Located near chadstone in VIC.
Please no low ballers as you will be ignored :-(
Engine details;
Ferrea OS Valve set rb26
ferrea double valve spring set rb26
ARP head studs RB26
Camtech camshafts - 274 degree with 9.35mm lift
OEM Timing Belt
Timing Belt Tensioner (both)
2 x RPM Adjustable Camshaft Pulley
Nitto I-beam conrods
Nitto Oil Pump
headgasket nitto drag series
nitto intake & exhaust gasket
ITB block water fitting
exhaust studs x 10
3x water hoses
Davies craig EWP alloy
JE Pistons & Rings
Main studs ARP
Head studs ARP
Main bearing set
piston ceramic coating
Misc
Acid clean block
welsh plugs
crack test block
crack test crankshaft
remove crankshaft oil gallery plugs
clean & linish crankshaft
Modify oil galleries for NPT plugs
Strainer plate
line hone
conrod alignment
conrod size check
check s/e clearance
check bearing clearance
Mock Assemble
squish areas in chambers
dismantle final clean & re assemble
check compression 8.5 - 1
block surface
balance full engine
check and dispatch
NO SUMP.
Accessories;
BPP fuel rail is twin entry 14mm rail
6 x Bosch EV14 1000cc injectors adaptors filters seals plugs (Flow Matched)
Heat treated manifold
Precision 6466 and 46mm dual gates plumbed back into dump
Stick with the project mate. Unfortunately you'll never get your money back for what you've spent so finish it off and get some enjoyment out of it!
  • 3 weeks later...
What sort of boost/bar is this engine designed for? I spent $14k on my engine and no one will buy it. Just keep it! Never get money back on engine builds. The engine is worth 10-12k worked.
  • Like 1
Hi guys, yeah selling anything is an undesirable experience these days.
Reasonable offers are within reach of asking price.
Prior to starting this build thought long and hard as knew it would be expensive, but as most have experienced it somehow always blows out.
I also looked high and low on here and the web for 12+ months so know that what i have is special and wont be replaceable if i sell this so in no rush.
Motor and parts are capable of big power but i went for injectors that would supply more than enough initial power.
If you look up my turbo setup on youtube its very impressive on an rb26.
So while listed for sale as many before me will attest to, not overly excited about selling it, but will if price is right.
Cheers
Paul
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
Currently not listed anywhere else nor have I been pushing to sell it. That said open to reasonable offers.
Not interested in splitting up motor, but will consider selling motor without hotside or clutch..
I've seen a lot of builds and only 1 other motor was to this standard.
Not only is this built for power but every single piece has been cleaned, polished or re-coated making it look new again.
  • 1 month later...
Hi, the motor has not been started as still needs to be wired up and needs a custom sump for its RWD application.
Its sitting in a z31, so would be much cheaper and faster dropping this into a GTR.
Its capable of much more but my end goal was around 550-600kw. Current injectors will apparently give you around the 400kw mark which build will do with ease.
There have been no shortcuts taken on this motor as there was no intention of selling it.
Cheers,
Paul
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
