rb26 rebuilt engine with exceptional attention to detail
Hi,
I've had my r33 rb26 engine totally rebuilt including head.
Unlike many rebuilds, nothing has remained untouched and all screws, metal parts, springs have been cleaned, polished, electrocoated.
Some components have been sandblasted and painted or powder coated.
All machining work performed by orger who worked on the r32s that ran in the v8 championships.
New end spring plastic brackets were machined for throttle bodies.
The motor has not been started and sits in a RWD 300zx.
The project has blown out and while in no rush, I'm considering selling and SEEKING EXPRESSIONS OF INTEREST.
Engine owes me over 30k, so will say asking for 30 and open to reasonable offers.
Located near chadstone in VIC.
Please no low ballers as you will be ignored :-(
Engine details;
Ferrea OS Valve set rb26
ferrea double valve spring set rb26
ARP head studs RB26
Camtech camshafts - 274 degree with 9.35mm lift
OEM Timing Belt
Timing Belt Tensioner (both)
2 x RPM Adjustable Camshaft Pulley
Nitto I-beam conrods
Nitto Oil Pump
headgasket nitto drag series
nitto intake & exhaust gasket
ITB block water fitting
exhaust studs x 10
3x water hoses
Davies craig EWP alloy
JE Pistons & Rings
Main studs ARP
Head studs ARP
Main bearing set
piston ceramic coating
Misc
Acid clean block
welsh plugs
crack test block
crack test crankshaft
remove crankshaft oil gallery plugs
clean & linish crankshaft
Modify oil galleries for NPT plugs
Strainer plate
line hone
conrod alignment
conrod size check
check s/e clearance
check bearing clearance
Mock Assemble
squish areas in chambers
dismantle final clean & re assemble
check compression 8.5 - 1
block surface
balance full engine
check and dispatch
NO SUMP.
Accessories;
BPP fuel rail is twin entry 14mm rail
6 x Bosch EV14 1000cc injectors adaptors filters seals plugs (Flow Matched)
Heat treated manifold
Precision 6466 and 46mm dual gates plumbed back into dump
Stick with the project mate. Unfortunately you'll never get your money back for what you've spent so finish it off and get some enjoyment out of it!
  • 3 weeks later...
What sort of boost/bar is this engine designed for? I spent $14k on my engine and no one will buy it. Just keep it! Never get money back on engine builds. The engine is worth 10-12k worked.
  • Like 1
Hi guys, yeah selling anything is an undesirable experience these days.
Reasonable offers are within reach of asking price.
Prior to starting this build thought long and hard as knew it would be expensive, but as most have experienced it somehow always blows out.
I also looked high and low on here and the web for 12+ months so know that what i have is special and wont be replaceable if i sell this so in no rush.
Motor and parts are capable of big power but i went for injectors that would supply more than enough initial power.
If you look up my turbo setup on youtube its very impressive on an rb26.
So while listed for sale as many before me will attest to, not overly excited about selling it, but will if price is right.
Cheers
Paul
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
Currently not listed anywhere else nor have I been pushing to sell it. That said open to reasonable offers.
Not interested in splitting up motor, but will consider selling motor without hotside or clutch..
I've seen a lot of builds and only 1 other motor was to this standard.
Not only is this built for power but every single piece has been cleaned, polished or re-coated making it look new again.
  • 1 month later...
Hi, the motor has not been started as still needs to be wired up and needs a custom sump for its RWD application.
Its sitting in a z31, so would be much cheaper and faster dropping this into a GTR.
Its capable of much more but my end goal was around 550-600kw. Current injectors will apparently give you around the 400kw mark which build will do with ease.
There have been no shortcuts taken on this motor as there was no intention of selling it.
Cheers,
Paul
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
