Hi everyone,
Car is a r34 GTR V spec.
Got a problem with my 4wd system. The 4wd and a-lsd lights go on and the car goes into rwd.
There is this ticking at the back of the boot; it is very audible near the reservoir. It ticks every 3 seconds. I think it only ticks when the car is stationary.
For the past couple of days, the 4wd and a-lsd light has not come on so I cannot check fault codes on the attesa unit, however, the ticking is still there.
What do you think? Any info would be much appreciated! Thanks in advance!
Edited by sr20dettttt
https://www.sau.com.au/forums/topic/469035-4wd-and-a-lsd-lights-on/
If you didn't get this sorted at the workshop let me know and i can help. Your 4wd and a-lsd light should come on with key at ignition, engine not started. If not you may have blown ABS fuse (driver footwell). Once you have lights back you can put the 4wd control unit in diagnosis mode using a paperclip :) it will flash codes on the abs warning light. R34 supplementary manual describes it all, i went through all this diagnosing a wiring fault in my R34.
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
