NM35 Factory Boost Gauge - dodgy readings
Hi all,
When I bought my 250t RS Four the boost gauge was showing some dodgy readings then packed in. After thinking it might be the well known dry joint issue, I dived in to the engine bay and discovered the vacuum hose had split and fallen off the plenum. Easy fix with some new hose and a zip tie, and all was well again.
Fast forward a couple of weeks and I developed a new problem, whereby the boost gauge would show 0 at idle, i.e. pulling no vacuum, building up to 1 under partial throttle. Then obviously it tops out so useless on boost.
This evening I tried the 'Scotty Fix' and wielded my soldering iron over the boost gauge sensor. I removed the old solder and renewed the joints on all three known failure points. I redid two I wasn't happy with, and confident that my soldering was now good I popped it back on the car and... it's still showing 0 at idle.
So either my engine pulls no vacuum, which I will test with my new mechanical gauge tomorrow (unlikely), or something is amiss electronically (likely). Has anyone come across a similar issue before? Could it be an issue with the gauge unit? Or should I try to find a replacement sensor? Are there any cheaper alternatives? These units are crazy expensive and difficult to get hold of.
Thanks in advance,
John
Stuck the Stack boost gauge on and it's pulling half a bar of vacuum at idle so definitely the sensor or gauge. Hopefully someone local can lend me a sensor to confirm it's that before I shell out.
