Skootron Posted February 14, 2017 Share Posted February 14, 2017 tein SS and whiteline sway bars hey all, I have an R33 sedan (s1) that I'm looking at fitting Tein super streets on and Whiteline front and rear sway bars (most likely 24mm adjustable front and rear) will also probably be going with the HD links. I was curious if anyone else has done the same or done similar mods and if there were any tips or anything else i might need to consider before sourcing and installing these. to avoid any confusion I'm after a comfortable yet rigid street/daily set up. any advice or input is welcome and appreciated, cheers Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/ Share on other sites More sharing options...
GTSBoy Posted February 14, 2017 Share Posted February 14, 2017 24mm adj front & rear will quite probably lead to the car being oversteer biased. I have mine set hardest front, softest rear, with otherwise well matched springs, and it is definitely lively at the rear end. 24mm adj front and 22mm fixed rear would be a safer setup. Not trying to dissuade you from going 24mm adj both ends....just warning you how it comes out in practice. The bars are pretty firm, but not as "firm" as the typical 8&6 kg springs you get on Teins. So you won't even really notice the influence of the bars on roll stiffness as much as I do. My front springs are only in the 5.x kg range. Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/#findComment-7811254 Share on other sites More sharing options...
Skootron Posted February 14, 2017 Author Share Posted February 14, 2017 22mm definitely sounds like a better option for what I'm shooting for. does this mean i should go with the bars to start off and give that a run then see how it performs and base my suspension selection on that? thanks heaps Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/#findComment-7811255 Share on other sites More sharing options...
GTSBoy Posted February 14, 2017 Share Posted February 14, 2017 No. Springs and dampers are the first thing. Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/#findComment-7811276 Share on other sites More sharing options...
hardsteppa Posted February 14, 2017 Share Posted February 14, 2017 And i wouldn't ever buy a non adj.swaybar ever again, cos u will end up 2anting adjustable. Superpro do a good bar in 22mm adj. Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/#findComment-7811305 Share on other sites More sharing options...
Skootron Posted February 15, 2017 Author Share Posted February 15, 2017 cheers for that GTS, looks like I'll be grabbing some coilovers first! I'll definitely look into the superpro bars as well, thanks Link to comment https://www.sau.com.au/forums/topic/469082-tein-ss-and-whiteline-sway-bars/#findComment-7811497 Share on other sites More sharing options...
