SOLD
1996 R33 Skyline Gts-t - manual, 250rwkw
Hey guys, it's finally time to part ways with my '96 R33 Gts-t. I've owned it for about 4 years now, just upgraded so this has to go!
I originally bought it in 2013 with about 112,000 on the clock, now has approx 146,000, rego till end of June 2017. I'm after $11,900. Located at Kogarah in Sydney
When i first bought this it came with a high-flowed R34 OP6 turbo, I wanted something more responsive so I got a brand new Hypergear SS1PU turbo about 6 months later - installed it & got the car retuned. It's always been great to drive, boost comes on early and hard, fullboost (18psi) around 3500-3750rpm in 4th. Dyno graph was a hair under 250rwkw in a stuffy dyno room. Next step would be to slap in some larger injectors + larger fuel pump and run E85 for something closer to 300rwkw
Serviced regularly and always taken care with it, it's always been a great reliable car. Handles great, sounds great, it's got lots of induction noise & gear changes sound very noice
I've also got a huge pile of receipts and stuff for the car + dyno sheet, spare ECUtalk cable
Mod list:
Nistuned z32 ECU (tuned by Toshi from SAU)
Greddy profec B Electronic boost controller
JJR bellmouth stainless dump/front pipe
Ecutalk consult port display (displays RPM, load, fuel economy, various engine/temp sensors + many many more functions)
Fujitsubo catback exhaust - twin tip, good sound, not droney
80mm metal turbo intake pipe
Z32 AFM with Tomei plug
JJR coilpacks
Apexi pod filter
Blitz return flow FMIC (painted black)
Turbosmart recirc BOV
Nismo 555cc injectors
Nismo intank fuel pump (wired for alternator voltage through a relay)
Jim Berry full monty carbotic clutch
BC racing br coilovers
Front & rear Whiteline adjustable sway bars
Whiteline subframe pineapples
Nismo front strut brace with master cylinder stopper
Nissan rear strut brace
Tomei hicas lock bar kit
18" Speedy wheels, Hancook Optimo rubber all round - heaps of tread left
Nismo gear knob
Boost gauge
Genuine Nissan floormats
Pioneer headunit with bluetooth, USB, AUX input
12" MTX subwoofer, 6" Response splits up front - both wired to 4-channel amp in the boot
Windscreen replaced approx 1 year ago due to stone chip
Radiator (reconditioned by NATRAD) & Century battery approx 2 years old
The bad:
Driver's side window has a small scratch in the tint
Tacho usually jumps around (common R33 problem)
Small paint chip on front left edge of bumper from when a Taxi nudged me in a parking lot @ 5km/hour
Not interested in swaps or lowball offers - if you have 6k to spend look elsewhere
PM me if you're interested!
Pull your gauge cluster out and reflow(melt) the solder on all the circuit joints on the back of the tachometer. Worked perfectly for mine a few years ago and hasn't played up since.
  • Like 1
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
