Wheel alignment
I've searched and found some info but nothing overly comprehensive.
I have attached the specs for alignment for a v36 coupe from the service manual of a G37 (assume they are the same). I've got an SP coupe  but assume it doesn't matter if it's a sport or not.
From my understanding caster is adjustable front and rear. Alignment same. But camber is only adjustable in the rear which is only minor adjustments. No camber  adjustment in the front on stock suspension.
Getting it done on the weekend (along with sway bars) so hoping this is all correct.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/
I'm going to aim for nominal. I understand more negative should improve cornering (within limits) but wear tyres out.
Caster will change how much it wants to drive straight or corner. At the moment it's too sensitive to turning, especially on high speed corners.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811658
If you're in Sydney, there's a guy I go to in Granville (Pedders) who knows his cars very well and always performs excellent alignments on my vehicles.
I'd suggest you take your car to him and tell him what you want to achieve. What he says is gospel, in my opinion.
  • Like 1
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811680
31 minutes ago, V35_Paul said:
are you planning to dive on the track?
or is this just everyday driving?
It's a daily that will eventually hit the track for the odd weekend. Was planning a track s15 but decided to buy this as a great daily instead with the odd track day. But mostly daily.
Yes I am in Sydney. I have it booked in for the sway bars (whiteline - see other thread) and full allignment at Blairs Tyres in Narellan. I have had great experience there previously on my S15. I went ot Pedders in Campbelltown and they offered great service (suspension sqeak unsolved because it was wet but they didn't charge me) but they quoted like 5 hour labour + full price for the sway bar... So decided to go where I knew. I'll give your suggestion some thought though as I know how much a bad alignment can change handling as I had this on the s15 with Bob Jane.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811685
There's a big difference between tyre shops and suspension shops when it comes to wheel alignments. I wouldn't waste my time (and money) on any of those idiots.
That said, no one Pedders is the same as another either. That's why without knowing the folks at Campbelltown, the only Pedders I go to is in Granville and wherever he goes, I'll follow, because it's not about the shop/chain. It's about the one dude with the knowledge that I'm referring to and where he just happens to be.
  • Like 2
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811689
I hear you. Thanks for the suggestion.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811697
6 hours ago, Hank Scorpio said:
I know it wasn't your initial question but let me chime in all the same. Get yourself a set of adjustable rear camber and toe arms mate, your car will love it!
So I'm assuming you're saying the v36 likes more rear camber?
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811767
Sorry mate, should have been more in depth. The amount of camber and toe adjustment is so minimal that (especially if a car is lowered) optimum wheel alignment specs can't be achieved with the factory adjustments. If the car is even slightly lowered it will have way too much negative camber in the rear and god knows what toe settings.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811831
Ahh makes sense. No plans to lower my car at this stage. If I do change I will factor those bits on aswell though.
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7811837
  • 5 months later...
Well finally getting my wheel alignment done (did the sway bars myself) with the new tyres on the weekend.
If anyone has any feedback on their wheel alignment on the v36 then feel free to chime in.
I've got the SP coupe. All suspension standard except for the whiteline sway bars.
Edited by Pete_Repeat
https://www.sau.com.au/forums/topic/469106-wheel-alignment/#findComment-7841689
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
