30 minutes ago, Roy said:
LOL Price? They all seem 6k. For me thats another 6-9 months of saving over an ebay piston/rod deal for 2k:( Baffles me that peple have the disposable income to shell out on stuff...by baffle i mean envious. I am still trying to piece my car back together after 2 years of being off the road and tired of being broke and spending all my spare cash on cars :(
You're an amateur.  I'm 4 years and counting off the road! :2_grimacing:
I agree with both of you but the "cheap" option is to build an RB30 as opposed to a stroker.  Stroker is sooooooo much easier in the long run than the RB30 though when you take into consideration all the other factors that come into making the thing fit in the engine bay.
In theory it's only another $1000 or so to build a 30 (mainly just extra machining) over the 26 but +++++ when it comes to getting the whole show up and running.
  • Like 1
Why would you leave the factory throw crank in there when for a little bit more you could have a stroker?
You're paying for machining, assembly, studs, gaskets, pumps and consumables anyway.
Baffles me why guys go to all that effort and leave it standard capacity.
LOL Price? They all seem 6k. For me thats another 6-9 months of saving over an ebay piston/rod deal for 2k[emoji20] Baffles me that peple have the disposable income to shell out on stuff...by baffle i mean envious. I am still trying to piece my car back together after 2 years of being off the road and tired of being broke and spending all my spare cash on cars [emoji20]
Remortgage my house to start a tuning buisness, with government tax incentives I ended up with a decent tax return that I blew on a motor now am completely broke again wishing I could afford a turbo lol
I think my R34 build has now been 9 years off the road. And I've been paying rego this entire time :(
  • Like 1
wow... mine has been 3 months and it feels like ages - car is covered in bird shit and dust too (if that adds any bonus points).. also accidentally scrapped the side of the car with the engine stand LOL
haha, mine has lots of scratches too from various garage incidents. I usually wash it once a year or so, its too depressing seeing it under all that dust.
I just decided to give myself a deadline of September 2017 to get it running again :)
Don't know about Aus but in NZ you can put rego on hold (no cost) when the car is off the road and just resume when its ready to go.
Short block build costs basically go something like this.
Strip clean and measure
Sonic test bores and cracktest deck
Bore and hone then line bore if reqd
Deck or finish the head surfaces
Crack test and check crank for straightness repair if required
Fit oil restrictor
Drill oil return holes and deburr oil return galleries at rear of head
Fit crank collar if required
Clean everything again
Fit new freeze plugs
Paint block
Fit studs if requested
Test fit and measure main bearings and measure journal sizing
Test fit piston ringless and measure deck hieghts and block twist
Size rods to new pins and file fit rings
Dummy up short assebbly and recheck bearing clearances
Disassemble and clean components.
Final assembly and full torque of short engine. Fit ancillary items as requested such as oil pump, sump, heat exchanger and oil filter block ect
So. Suddenly you need to add parts onto this and the cost of the machining. This is why some people who build engines charge what they do.
Reliable, fast, cheap.  Pick 2.
As far as I know we don't have that in my state, unfortunately. I have kept it registered as if the government ever looks under the bonnet it's not going to to be registered ever again haha.
1 month off road for me so far, getting groceries without a car is starting to get old.
I have been exploring a rebuild option for my Neo and realistically there is no change whatsoever from 5k, for even the most basic rebuild. I have marked my bores too plus suspect a crack in the block so in practice it will well beyond 5k. Replacement engine is my preferred choice, just very hard to source at the moment.
Given where 32/33/34 prices are at the moment (GT-R's notwithstanding) you must be willing to spend the cost of the car or thereabouts if chasing a properly done big power RB engine build IMHO.
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 馃槩
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
