30 minutes ago, Roy said:
LOL Price? They all seem 6k. For me thats another 6-9 months of saving over an ebay piston/rod deal for 2k:( Baffles me that peple have the disposable income to shell out on stuff...by baffle i mean envious. I am still trying to piece my car back together after 2 years of being off the road and tired of being broke and spending all my spare cash on cars :(
You're an amateur.  I'm 4 years and counting off the road! :2_grimacing:
I agree with both of you but the "cheap" option is to build an RB30 as opposed to a stroker.  Stroker is sooooooo much easier in the long run than the RB30 though when you take into consideration all the other factors that come into making the thing fit in the engine bay.
In theory it's only another $1000 or so to build a 30 (mainly just extra machining) over the 26 but +++++ when it comes to getting the whole show up and running.
  • Like 1
Why would you leave the factory throw crank in there when for a little bit more you could have a stroker?
You're paying for machining, assembly, studs, gaskets, pumps and consumables anyway.
Baffles me why guys go to all that effort and leave it standard capacity.
LOL Price? They all seem 6k. For me thats another 6-9 months of saving over an ebay piston/rod deal for 2k[emoji20] Baffles me that peple have the disposable income to shell out on stuff...by baffle i mean envious. I am still trying to piece my car back together after 2 years of being off the road and tired of being broke and spending all my spare cash on cars [emoji20]
Remortgage my house to start a tuning buisness, with government tax incentives I ended up with a decent tax return that I blew on a motor now am completely broke again wishing I could afford a turbo lol
I think my R34 build has now been 9 years off the road. And I've been paying rego this entire time :(
  • Like 1
wow... mine has been 3 months and it feels like ages - car is covered in bird shit and dust too (if that adds any bonus points).. also accidentally scrapped the side of the car with the engine stand LOL
haha, mine has lots of scratches too from various garage incidents. I usually wash it once a year or so, its too depressing seeing it under all that dust.
I just decided to give myself a deadline of September 2017 to get it running again :)
Don't know about Aus but in NZ you can put rego on hold (no cost) when the car is off the road and just resume when its ready to go.
Short block build costs basically go something like this.
Strip clean and measure
Sonic test bores and cracktest deck
Bore and hone then line bore if reqd
Deck or finish the head surfaces
Crack test and check crank for straightness repair if required
Fit oil restrictor
Drill oil return holes and deburr oil return galleries at rear of head
Fit crank collar if required
Clean everything again
Fit new freeze plugs
Paint block
Fit studs if requested
Test fit and measure main bearings and measure journal sizing
Test fit piston ringless and measure deck hieghts and block twist
Size rods to new pins and file fit rings
Dummy up short assebbly and recheck bearing clearances
Disassemble and clean components.
Final assembly and full torque of short engine. Fit ancillary items as requested such as oil pump, sump, heat exchanger and oil filter block ect
So. Suddenly you need to add parts onto this and the cost of the machining. This is why some people who build engines charge what they do.
Reliable, fast, cheap.  Pick 2.
As far as I know we don't have that in my state, unfortunately. I have kept it registered as if the government ever looks under the bonnet it's not going to to be registered ever again haha.
1 month off road for me so far, getting groceries without a car is starting to get old.
I have been exploring a rebuild option for my Neo and realistically there is no change whatsoever from 5k, for even the most basic rebuild. I have marked my bores too plus suspect a crack in the block so in practice it will well beyond 5k. Replacement engine is my preferred choice, just very hard to source at the moment.
Given where 32/33/34 prices are at the moment (GT-R's notwithstanding) you must be willing to spend the cost of the car or thereabouts if chasing a properly done big power RB engine build IMHO.
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
