RB30E Specifications, periodic maintenance, and exploded views.
Easy mods for small power gains
Pod filter installation
Pinouts
Timing
Conversions/modifications:
RB30E --> RB30ET conversion
RB30E --> RB30DE/T conversion
Auto to Manual conversion
Supercharging
Other useful links:
R31 models... specs & differences
What to look for (common problems) when buying an R31
CalaisTurbo (NA & Turbo info) - A great place to source parts for your turbo conversion!
R31 Skyline Club
General Specifications
6 cylinder overhead cam
Bore - 86mm
Stroke - 85.0mm
Capacity - 2962 cc
Compression ratio - 9.0:1
Overall Length - (mm) 4,653
Overall Width - (mm) 1,690
Overall Height - (mm) 1,395
Wheelbase - (mm) 2,610
Spark Plugs
Type - BCP 6ES-11
Hot type - BCP 5ES-11
Cold type - BCP 7ES-11
Spark Plug Gap - 1.0-1.1mm
Firing Order - 1-5-3-6-2-4
Distributor
Make - Bosch
Rotation of rotor - Anticlockwise
(early models have a Mitsubishi distributor)
Engine Idle speed - 700 ± 50 RPM
Ignition timing - 15° ± 2°bdtc at 700 ± 50 RPM
Compression Pressure
Standard - 1196kPa
Minimum - 883kPa
Thermostat
Type - wax pellet
opening temperature - 76.5 deg
Ignition coil
Primary resistance - 0.9-1.0 ohm
Secondary resistance - 9000-10000 ohms
High pressure fuel pump
Type - electric roller
Fuel pressure at idle - 206kPa
Fuel pressure at zero vacuum - 255 kPa
Refill Capacities
Oil
With filter change - 4.4 litres
Without filter change - 4.0 litres
Coolant
Refill capacity - 9.0 litres
Reservoir tank - 0.6 litres
Transmission
Manual - 2.0 litres
Automatic - 7.2 litres
Misc
Rear axle - 1.7 litres
Power steering - 1.0 litre
Fuel tank - 61 litres
Replacement filter part numbers:
Ryco oil filter - Part number Z145A
Ryco air filter - Part number A360
Ryco fuel filter - Part number Z202
https://www.sau.com.au/forums/topic/46912-rb30e-specs-maintenance-mods-faq/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
