New ECU
Hi guys, I have a problem with my ECU and will look to purchase a new/used one over the next week. I am aware of the NATS issue and would need to get the ECU to talk to the BCM to get keys to work. Is the procedure the same as reprogramming "new" FOBs to work with the car? Meaning I could get Nissan to just reprogram my keys to the new ECU?
Thanks
https://www.sau.com.au/forums/topic/469177-new-ecu/
There's a fair bit that needs doing, according to the workshop manual:
  1. Initialise the NATS system and re-register all keys
  2. Register the VIN
  3. Relearn accelerator pedal released position
  4. Relearn throttle valve closed position
  5. Relearn idle air volume
If the ECU you buy is a new one (i.e. completely virgin, no prior data programmed into it), then the procedure for step 1 should be fairly straightforward and automatic. Otherwise, it will need Nissan to do that for you with their Consult tool.
Steps 2 and 5 will definitely also require the same Consult tool.
Steps 3 and 4 don't need the Consult tool.
All in all, there's no technical reason why your local Nissan dealer couldn't do this for you, unless they're arseholes. In which case, if I was in WA, I'd be happy to volunteer my Consult III+ tool and have some nerdy fun helping you out, provided you have the PIN tag, as I don't have the immobiliser module for the scan tool.
https://www.sau.com.au/forums/topic/469177-new-ecu/#findComment-7812763
Where can I get the PIN tag?
For 1. it seems like it I get a new one I could get it to pair with the key by just putting into the key fob holder...should be that easy. However with used one it seems like Consult tool will need to be used to reprogram NATS etc....
I called one of my contacts at a Nissan dealer...they were asked not to help at all with imports. Anyway he said to be even if I get an ECU in, I need to reprogram the ECU and Keys....which I didn't really understand. I thought as long as I got the ECU with the same part number as mine, I would only need to worry about the keys...(and 3,4,5) which we both agree on.
In your reading do you see anything that says the ECU needs to be reprogrammed to run on the car?
https://www.sau.com.au/forums/topic/469177-new-ecu/#findComment-7812769
The PIN tag is a little metal plate, around 5mm x 12mm which has four digits stamped into it. Mine was attached to both of my keys when I received the car. If that's missing, you need the immobiliser module for the Consult III+ tool to bypass the PIN checking, or otherwise it's a matter of making enquiries back to Japan to have it calculated from other numbers found on the BCM sticker or something like that. There's a thread all about that somewhere in this forum.
If the ECU is brand new, then you'll be able to start the car as per the virgin ECU procedure.
If it's a second hand ECU, which therefore has the details of another vehicle programmed into it, then you will need to reprogram it as previously stated.
Alternatively, do what I did five years ago when I bought my car and jump on AliBaba.com to buy a Consult III+ tool, software and immobiliser module. ;)
https://www.sau.com.au/forums/topic/469177-new-ecu/#findComment-7812773
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
