Hi all,
Need advise. ..
Long story short , do i need to skim my rotors that have been lying on the grass/dirt for more than a year?
I've measured the thickness for both front and rear rotors and they have not thin out at all . Not even 1 mm :) obviously they're full of rust and dirt . I've removed the dirt but wondering if i should skim it to remove rust and also balance the rotors before fitting them? (Not even sure if people balance rotors or not)
I've attached 1 pic to pretty much show how It was kept under the weather lol...
https://www.sau.com.au/forums/topic/469195-do-i-need-to-skim-rotors/
You can give them a rub with abrasive paper to try to remove a lot of rust.  They will not have changed dimensions in a way that you can measure, so you shouldn't worry about that.  They only real problem with using paper to clean them is that you may make the surfaces not evenly flat whilst doing so.  But you'd have to rub pretty hard in one spot a lot longer than other spots to achieve it.
Oddly enough, it's not the friction surface you need to worry about the most.  If there is thick rust on the hub surface, you need to clean that up.
Will it be easier if i send it to a workshop to skim it to remove rust? I don't mind saving some money to do it myself though but i need guidance...
Reason i ask about skimming rotors is because a friend told me i should get it skimmed & balanced as well... do people even balance rotors? ?? I mean the last thing i need is driving and feeling a lot of vibration/ shake. ..
No, rotors do not get balanced.
My position is never get rotors machined unless they absolutely need it.  You lose material and life from them every time you do it.  The only time to do it is if there is a lip than needs to be gotten rid of, or grooves in the surface, or serious warpage.  Although serious warpage should probably prompt replacement.  The other reason people get rotors machined is when they think they have warped rotors but they actually have uneven build up of pad binder material on the rotor faces.  This can also be successfully fixed with abrasive paper.
If your surfaces are nice and flat and you don't have a lip on the outer edge, try paper first.
Lastly, I never get rotors machined off the car.  It's just so easy to get the mobile brake guy to come and do them on the car, whether at home or in a workshop.  So you may as well just clean them up yourself and see how they go before moving onto machining if you need to.  But it is important for you to realise that there are other reasons for you to get braking vibrations also.  It may not necessarily be that the rotors are not good.  So if you do put it all together and run it and find vibration, you'd be well advised to look at the other reasons.  At the least you can put a dial gauge onto the car and spin the rotors to see if they have a lot of runout other wierdness going on, and this can be done better on the actual hub and bearing that they are working on than a lathe anyway.
  • Like 2
Well, they do - at the manufacturer. One of the RDA's I installed recently had a nice straight 'slot' cut on the outer rim of the disc at one single spot, whilst the other rotor didn't - I am 99% certain it's to balance it. The pair was less $200 so pretty cheap compared to mucking around with rusted rotors.
Also re machining rotors on hubs, it's a good option but some guys only do plain ones, the one my shop uses wouldn't touch my slotted DBA's on the car.
When re/installing rotors make sure you check run out and oscillation: https://www.sau.com.au/forums/topic/448613-r34-gtt-brake-improvement-without-breaking-the-bank/?do=findComment&comment=7803377
As others have said you definitely want to check the condition of those calipers. Rebuilding them at a workshop will cost a bit (my GTT fronts rebuild was around $400 drive in/drive out), but brakes is one of those things that you need to be pretty confident in what you're doing to DIY.
Also: If that's what your rotors and suspension looks like, what the rest of the underbody like??
I guess you've harvested the potatoes already. :369_sweet_potato:
Hi Mate,
Please either re-machine those discs or get new ones (your pads will thank you), rebuild the calipers (seal kit), replace the studs and clean the rust off those hubs and inside the disc hat. You should then have a safe ride.
Cheers
Hi Mate,
Cheers
do what this man says, he knows.  and welcome back to the forums :)
10 hours ago, -S- said:
I'm doing all except the studs...
Studs are cheap and easy to replace. Those in the picture look like they have advanced corrosion and aren't safe.
Assuming you can get some wheel nuts on don't leave it too long.
After changing wheel studs three times because of "technicians" who can't put wheels back on my Subaru properly, yes they are cheap to change but quite a crucial part of keeping your car on the road.
https://partsouq.com/en/search/all?q=43222-28B00
I thought u meant the stud of the caliper. Lol. Yeah i guess I'll look into it. .. thanks
No Worries and good luck.
Give everything a good ol soak in WD40 a day or more before. Take the pads out first.
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
