GtX2863R twin turbos
Selling my brand new Garrett GTX2863 turbos which have had plenty of work done to them to make them the best option for bolt on twin turbo options.
I've had 2860-5 turbo front housing covers professionally milled by GCG turbos to suit the GTX turbo front compressor wheel so that factory or bolt in aftermarket piping can be utilised with the GTX turbos.
Brand new 2860-5 rear housings were bought and ported to allow maximum airflow into the GTX turbine wheel. The port is a perfect matcgh for the 6boost twin turbo manifolds which I also have for sale.
Turbonetics dual port wastegate actuator was installed to help control high boost pressures while still allowing an external boost controller to have a wide range of adjustment in boost range.
The turbos are fitted with AN oil feed, drain and water fitting so braided lines can be used on the turbos if desired, otherwise they can be removed and used with stock lines if desired.
These turbos have been proven to make 700hp atw with a stock locking engine bay and great response as expected from twins with billet wheels
Price is 3000 posted australia wide. Thses cost me a fortune to have built and they are still brand new in the box. I can do a deal if you buy the 6 boost manifold with the turbos.
I also have numerous other new engine parts, PM me if you require anything.
Thanks
https://www.sau.com.au/forums/topic/469198-gtx2863r-twin-turbos/
  • 2 months later...
They should bolt up to a stock set of manifolds by the look of them but I would really suggest grabbing the 6boost manifolds with them if you are thinking about getting them. I have a very similar setup in my car and ended up scouring around for almost 12 months to find a decent set of twin manifolds but ended up with a set of really nice cast ones from Artec. 6 boost were definitely on the list quality wise but Kyle was not making anything for twins on an RB off the shelf at the time.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
