GtX2863R twin turbos
Selling my brand new Garrett GTX2863 turbos which have had plenty of work done to them to make them the best option for bolt on twin turbo options.
I've had 2860-5 turbo front housing covers professionally milled by GCG turbos to suit the GTX turbo front compressor wheel so that factory or bolt in aftermarket piping can be utilised with the GTX turbos.
Brand new 2860-5 rear housings were bought and ported to allow maximum airflow into the GTX turbine wheel. The port is a perfect matcgh for the 6boost twin turbo manifolds which I also have for sale.
Turbonetics dual port wastegate actuator was installed to help control high boost pressures while still allowing an external boost controller to have a wide range of adjustment in boost range.
The turbos are fitted with AN oil feed, drain and water fitting so braided lines can be used on the turbos if desired, otherwise they can be removed and used with stock lines if desired.
These turbos have been proven to make 700hp atw with a stock locking engine bay and great response as expected from twins with billet wheels
Price is 3000 posted australia wide. Thses cost me a fortune to have built and they are still brand new in the box. I can do a deal if you buy the 6 boost manifold with the turbos.
I also have numerous other new engine parts, PM me if you require anything.
Thanks
https://www.sau.com.au/forums/topic/469198-gtx2863r-twin-turbos/
  • 2 months later...
They should bolt up to a stock set of manifolds by the look of them but I would really suggest grabbing the 6boost manifolds with them if you are thinking about getting them. I have a very similar setup in my car and ended up scouring around for almost 12 months to find a decent set of twin manifolds but ended up with a set of really nice cast ones from Artec. 6 boost were definitely on the list quality wise but Kyle was not making anything for twins on an RB off the shelf at the time.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
