Fuel pump not receiving power
hey guys,
so i have recently starting working on my 98 four door
i have gotten it turning over with the starter but it is getting no fuel.
i pulled the pump and have found a replacement for it, ready to go but decided to test the connections and found there is no power.
i have traced it back, checked fuses, got to the relay and found there is only one relay and two terminals.
so questions are:
is the fuel pump relay in the boot behind the brake lights? the color of the cable running to the pump and to these terminals seem to be different
how do i tell if a relay is working? i have a multimetre but i am only getting continuity on some posts.
do both connections require a relay?
https://www.sau.com.au/forums/topic/469201-fuel-pump-not-receiving-power/
  • 4 weeks later...
There are a few good relay test videos on you tube. As far as the pump wiring goes I recommend you do a search for direct power feed for fuel pump in here. Do you plan to do any mods or is the car already modified from standard? What pump are you running?
