Overactive Radiator Fan
My car is an R32 Gtst. Not too long ago the fan started to run non-stop and after doing some research on here I replaced the viscous clutch with this one, but the fan still runs a lot more than it should, my temperature gauge not getting up above 70C on days that are about 35C, I'm not sure my thermostat would even open at these temperatures. Because of this I also replaced the ECU Water temp sensor hoping that that would sort it out, but still, the fan is going too much. I am not sure what to check next. Multimeter to make sure the sensor is getting power? Should I get a consult cable and plug ECUtalk and see if there is an error code?
I am not sure what I should try. If I need to just take it to a mechanic I will, but am trying to save the expense if I can. Any guidance very welcome.
Thanks guys.
https://www.sau.com.au/forums/topic/469210-overactive-radiator-fan/
Those viscous hubs are mechanical and engage at a certain temperature detected by the brass coil you see on the front.
ECU controls none of this.
I had an issue once when I purchased a brand new hub. It took some time before it actually started functioning correctly.
I believe there's a run in procedure you need to follow when installing the new hub. Were instructions included with your new hub?
I called it quits and found myself a near new condition R34 GTT hub which also suits the R32 fan. Genuine item and at least 10 years newer.
No issues so far. I have 3 spare genuine hubs all in working condition. If you want to go that route let me know and I can send one your way.
Edited by jmknights93
For what its worth, I've had a Davies Craig fan hub, and it was the worst thing in the world. It may as well have been a solid fan hub, it NEVER went any speed besides flat out. The genuine fan hub on the car originally was by far the best. I have a Dayco fan hub now designed for an RB30 in an R31 Skyline. This is only because it doesnt have as long a shaft and I had some clearance issues with my new radiator and fan shroud. I would say it is just about on par with a genuine one. Probably due to it being for a different model, the temps its designed to work at might be a touch different, but for the most part it is perfectly fine.
FYI genuine ones are about $300-$400 usually
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
    • Yes, ther are plenty of [racist statement alert] terrifying 50+ yr old ladies of a certain ethnic origin who have no demerits yet still manage to park their cars on top of roundabouts, hanging out of multistory car parking structures and other wild shenanigans. Somehow they puddle through years of driving without ever attracting the attention of the cops, yet the whole time, they are an instant away from doing something spectactularly stupid.
