building motor help needed
So i finally put a rod through the block looking for about 500 hp.  So I am getting another rotating assembly im thinking for parts cp pistons, manley rods and spool import billet oil pump gear  then swapping my head over.  http://www.rawbrokerage.com/cp-pistons-manley-rods-combo-r33-rb25det/
Im not to sure what head gasket or thickness  I need and if i should run race main bearings and end bearings or if I should just go oem.
Can you provide insight on what other parts i will need or you recommend as this is my first build.
https://www.sau.com.au/forums/topic/469225-building-motor-help-needed/
Go to the forced induction section and read through the latter part of the RB25 turbo upgrade section - some people put a fair bit of detail in the description of their engines (some less so). If you are going to the expense of forged components then you should plan to fully balance the whole rotating assembly. Aim for better than 9:1 compression. I would get a Tomei metal gasket simply because they can be reused in the event that your head has to come off again. Is it a street car or do you plan to track or drag race it?
so far ive come up with
rb26 rods
oem bearings
spool billet oil pump gear
extended crank collar
balanced bottom end
forged pistons 86mm 9.0.1
tomei headgasket
tomei poncams
oem gasket set
arp head studs
arp main studs
  • 1 month later...
Dont buy bearings until you know what clearances you want to run.  If you are using stock rb26 rods install the rod bolts, torque to spec and check the sizing. Most of them need to be resized with arp fasteners. Same goes for the main studs. Install, torque and measure the tunnel. I highly doubt you will have a dial indicator setup on a bore guage small enough and long enough to accurately measure it. Bearings dont score journals. Poor clearance and assembly does
  • Like 2
  • 1 month later...
  • 1 month later...
The motor spins freely I unplug the cad and spun it with the starter for 30 sec to try and build oil pressure before starting it stock oil pump internals was swapped out for spool imports I'm going to try pouring some oil down the filter housing so it runs into the pump and try again
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
