Hi guys and gals..... I am preparing my GTR for circuit racing and need to replace my sump with one with a larger oil capacity and better baffled. I came across one manufactured by GREX at NENGUN performance parts (nengun.com) but no details such as the sump's oil capacity and whether it sits lower than the original sump.
Does anyone out there have any info or can refer me to someone who does?
https://www.sau.com.au/forums/topic/46929-grex-sump-for-r33-gtr/
Hi.
The TRUST / GREX sump does hang lower. According to an engineer mate of mine who does a lot of V8 Supercar work, you cannot go past the Jun sump kit (baffle kit) for light circuit racing.
Good luck.
Powerplay in Sydney got hold of the Trust Sump kit for my race car, it includes a sump extension you weld in, a new oil pickup and some additional baffles.
I thought it was 8l not 10l though, the 10l might have included an oil cooler?
Merli has also just fitted the Trust extension kit. It seems like a great option when compared to the price of the baffle only kit from Jun and Tomei. Increased oil capacity, baffles and modified pickup.
Nengun and Greeline can supply these, alternatively if you want to buy from a local store im sure Advan in silverwater has them in stock
  • 1 month later...
Sorry to bring up a reasonably dead thread but has neone actually used one of these kits on the track and to what degree of success was experienced, i just purchased one of these kits (the grex) and it is waiting to be installed on the car. Its the kit with extension oil pickup and extra baffles, is this kit sufficient to eliminate the common oil starvation problems GTRs face when at the track when used in combination with a good quality oil cooler.
Cheers
John
haha yes, race car has done a heap of track days over 12 months. It seems to be a well designed kit, and no doubt just the extra capacity on its own is a help.
We also run restrictors in the oil feed to the head, and I have heard of people using baffles or foam in the head as well.
Yes the R31 N1 has an oil cooler although no filter relocation kit, so total oil capacity is up another litre or so, up to about 8 litres from memory
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
