GreyZ33Track Posted March 2, 2017 Share Posted March 2, 2017 R32 Gts4 ECU burned Resistor...advice Quote let me preface this by stating I am no electrical guy. I can do mechanical, but thats about it. Anyways, I upgraded my turbo and injectors and then installed my Nistune ECU a few weeks ago. The motor when fired up sounded like a wrx...found that unplugging coilpack #4 yeilded no change...boom, dead cylinder. Pulled the injector, injector is fine....then thought to check ecu since it was just sitting on my floorboard...Burnt resistor that corresponds to cylinder 4. Now, i dont recall disconnecting my battery before doing all this work, and am hoping that may have been the cause as i was moving a lot of stuff around and out of the way. I am replacing the resistor, but would like to know what else I should be looking at that could have caused this, besides me being an idiot and not disconnecting my battery before doing all this work. Thanks in advance for any tips or advice. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/ Share on other sites More sharing options...
KiwiRS4T Posted March 2, 2017 Share Posted March 2, 2017 Have you posted elsewhere? Anyway try replacing the resistor (should be cheap) and see what happens. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814620 Share on other sites More sharing options...
GreyZ33Track Posted March 2, 2017 Author Share Posted March 2, 2017 Yah, a computer repair shop is replacing it for $15...should have it back today....just trying to prevent a failure again....battery is already disconnected and will be connected after everything is in position. Posted on Nicoclub.com as well. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814644 Share on other sites More sharing options...
GH05T Posted March 3, 2017 Share Posted March 3, 2017 in my 'not that knowledgeable' head, the thought would be, what made the resister pop and really burn? somethings not right. not something you want failing while in motion/ high rpm. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814768 Share on other sites More sharing options...
GreyZ33Track Posted March 3, 2017 Author Share Posted March 3, 2017 Exactly my thought. Do I just follow that pinout and look for bare wire? Is there a way to test it without having the ecu installed? Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814779 Share on other sites More sharing options...
GH05T Posted March 3, 2017 Share Posted March 3, 2017 i would be more looking at how the nistune was installed. if you change something then it goes bad its usually that. ask the guys fixing it. their gonna know allot more than me Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814795 Share on other sites More sharing options...
GreyZ33Track Posted March 3, 2017 Author Share Posted March 3, 2017 I sent the ECU straight to Nistune in Australia to ensure it was installed correctly.,,no way thats the problem. I just installed the ecu with the new resistor installed...cylinder 4 still dead, but resistor is good. Ran noid tester and injector is firing...going to test ignitor next. Finding conflicting info on how to test... Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814803 Share on other sites More sharing options...
GreyZ33Track Posted March 3, 2017 Author Share Posted March 3, 2017 (edited) Ok, so installed the repaired resistor ecu, used the injector nodes, injector is firing and the the problem is still there...definately no spark. Since the harness goes to the ecu and resistors off the ignitor, i measured the resistance across the 6 pinouts..all measures the same except cylinder 4 wire, which read .02. I need to do more testing, but does that imply that wire is being grounded somewhere? Can someone please test theirs and see what they get? Edited March 3, 2017 by GreyZ33Track Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7814973 Share on other sites More sharing options...
zoomzoom Posted March 3, 2017 Share Posted March 3, 2017 Has your coilpack been blown out? Burning out a resistor isn't a small feat. It looks like a 22 ohm resistor, and it probably had a constant 12v across it to burn it out like that. However if the output was stuck on, that would have burned out the coilpack? Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7815017 Share on other sites More sharing options...
GreyZ33Track Posted March 3, 2017 Author Share Posted March 3, 2017 I will have to check the coilpack tonight...it was a 22ohm resistor. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7815022 Share on other sites More sharing options...
Guilt-Toy Posted May 22, 2017 Share Posted May 22, 2017 how did you go ? Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7830766 Share on other sites More sharing options...
GreyZ33Track Posted May 22, 2017 Author Share Posted May 22, 2017 Replaced resistor...still did not work. Ended up swapping the nistune board into another ecu and worked fine. Still not sure what caused the resistor to fry in the first place. Link to comment https://www.sau.com.au/forums/topic/469370-r32-gts4-ecu-burned-resistoradvice/#findComment-7830767 Share on other sites More sharing options...
