  • Replies 77
w00t the People For Less Sections Party (PFLSP) have won the vote :)
PFLSP ?
hmmm... if i look at it a bit... and move some letters around ...
and add an o.... or 2..
and just switch this one, with that one.... it almost looks like ....
POOFS
Heres my plan;
GENERAL
-General Automotive Discussion
-Vehicle Specific Discusion
---Stagea
---Ceffy
---etc
-Motorsport
-Importation
MAINTENANCE/MODS
As is, removing Bodykits (merge into general automotive).
WORLD
As is, move sports/news -> wasteland
Optinions?
Christian
Sounds great to me! :D
new layout roxxors, but may i suggest swapping the positions of GAD and Vehice Specific Discussion?
as it is right now is like having
Merli likes it:
a) up the ass
B) in his ear
c) none of the above
d) all of the above
General automotive is an abortion.
Plain and simple.
It's just being bombarded with posts from people who don't know where to post things.
I just went in there and filed everything on the first page into its own little section, and now it's an entire page of "moved" threads. (again)
I'd like to make another suggestion... lose 'general automotive' altogether.
If people want to post something that doesn't fit into one of the dozen or more existing forums, then it belongs in the wasteland.
i hate going into general automotive and seeing moved everywhere...
if it is going to stay the same, can we not have the moved things stay there?!?!
james.
This is why I'm pleading for it to be changed.
I can make it so the 'moved' things are't there, but that involves sending pm's to each poster, telling them where their thread has been moved to.
That may not sound like such a task when there are only one or two threads that need moving, but when it's 15 or so at a time, it's a bit overwhelming. :Oops:
OK.. I just went and moved another 9 threads (i think it was 9)
It took me almost 20 minutes to move them to their correct sections and notify the posters.
People just don't know where to post. :Oops:
  • 5 months later...
I personly tohught the bodykits section undermods and maintanence was good coz it was an ares for ppl to chuck around different ideas etc about that topic only, I was going to post a new thread up about this but decided i would search first and this thread loks good enough to sook in.
MY SOOK - Put bodykits back under Mods and Maintance......please :P
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
