New NISMO GT LSD Pro 2WAY Diff S13 S14 R32 R33
Due to part number stuff up from supplier this Nismo 2 way diff is up for grabs. It is the adjustable model that allows initial torque to be set without removing or disassembling the diff.
Part number is - 38420RS220
This item has only been opened to take the picture shown - comes with everything visible in the picture, including Nismo competition diff oil, bolts, gasket, bearings, seals, Nismo half shafts, decals, and certificate of authenticity.
Diff will fit in most Nissan's running an R200 pumpkin, from S13/14/R32/R33's. Package can come with extra 6 bolt drive shafts for $50 - good for spare or conversion but probably not worth posting them as the box will already be heavy.
Pickup Gold Coast QLD. Post Aus wide no problems with cheap Australia Post eParcel or courier rates.
Price is $1350 firm
Edited by GUWOP
BUMP - best offer takes it
Hopefully this helps someone in future - after some further research this part number is for S13, S14 and S15 models and the half shafts are 30 spline, which matches the bolt configuration for the 6 x 2 drive shafts. Thought I might be able to swap them for R32/33 models but no dice as the half shafts are 29 spline when they have the 5 x 1 bolt pattern. I have an R32 so as you can imagine this won't work.
Edited by GUWOP
Or.....you could just buy some 3x2 shafts for your R32.  That's what I did to put an S15 helical into my car.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
