New NISMO GT LSD Pro 2WAY Diff S13 S14 R32 R33
Due to part number stuff up from supplier this Nismo 2 way diff is up for grabs. It is the adjustable model that allows initial torque to be set without removing or disassembling the diff.
Part number is - 38420RS220
This item has only been opened to take the picture shown - comes with everything visible in the picture, including Nismo competition diff oil, bolts, gasket, bearings, seals, Nismo half shafts, decals, and certificate of authenticity.
Diff will fit in most Nissan's running an R200 pumpkin, from S13/14/R32/R33's. Package can come with extra 6 bolt drive shafts for $50 - good for spare or conversion but probably not worth posting them as the box will already be heavy.
Pickup Gold Coast QLD. Post Aus wide no problems with cheap Australia Post eParcel or courier rates.
Price is $1350 firm
Edited by GUWOP
BUMP - best offer takes it
Hopefully this helps someone in future - after some further research this part number is for S13, S14 and S15 models and the half shafts are 30 spline, which matches the bolt configuration for the 6 x 2 drive shafts. Thought I might be able to swap them for R32/33 models but no dice as the half shafts are 29 spline when they have the 5 x 1 bolt pattern. I have an R32 so as you can imagine this won't work.
Edited by GUWOP
Or.....you could just buy some 3x2 shafts for your R32.  That's what I did to put an S15 helical into my car.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
