Well after my r32 gtr fuel pump setup. We all came to the conclusion that it was over kill.
I going for 800 hp and may run E85 later on. I looking to do the simplest setup, intank would be great. I'm not looking to upgrade alternator or nothing that crazy. But I am willing to run a separate power supply. I just think it's hard to do in a r33 gtr due to the tank design. I'm just wondering what people has done to achieve these goals. I'm still searching and hope by making this thread, maybe I'll get some new up today suggestions.
https://www.sau.com.au/forums/topic/469514-r33-gtr-fuel-pump-setup/
Spend the change in Power FC Pro
Boy never letting it go aye. Lol
I see some duel 460 surge tanks by radium. For around 5 hundred dollars. Looks clean and simple. Do you really feel that lift pump will be good enough.??
We're would you recommend returning it from the fpr. To surge tank or fuel tank. Also with dual pumps would I need a fuel cooler.
I'm looking for the simplest setup. Also was looking at fuel lab stuff. Like there variable pumps.
I would get the Aftermarket Industries surge tank as they're a little more compact and also you're supporting Australian products :)
Although the Radium stuff is porn.
You could run 2x Walbro 460L pumps in the surge into the rail and stage them via your ECU, wait.... you can't do that on a PowerFC Pro.
Yes FPR return to surge tank, surge tank return back into fuel tank. If you're constantly on corn juice, no real need for a fuel cooler however it's always good to run one regardless. Some people who don't mind losing boost space actually run their fuel coolers in there.
I support Australian products all the time. I just got 2 manifolds from Kyle at 6 boost. To date I have ordered 6 or 7. Next I ordered 2 extended sumps from Rob at face fab. So I really don't mind. Oh. Don't forget a power fc pro from an Australian mate. Lol
I'm still looking at fuel setup other guys are using. I could however use an rpm signal switch or boost signal switch to stage the next pump, when running the pro. But I'm thinking about using the Haltech ps2000. I have joined there fourm and seeing if I can work things out. Last time I mest with it. I noticed it has 2 method of tuning.
Next I had to setup the actual timing. Like using a timing light with a spark plug wire on number one cylinder to get the right timing and then input it. Next was fuel pressure and a whole bunch of other stuff just to start up. One of my problems was getting a good wiring diagrams of the plug and play harness for the pre-made harness that came with the ecu. Next was extra pins for the plugs to run extra stuff. Like outputs. I feel all of this is just me being lazy. Hence why I like the power fc.
I'll give it a good this time.
I know I'll need help.
2 hours ago, Borci88 said:
I would love to see a GTR make 800hp on 98 through a single 8mm fuel line... let alone when you add E85..
he's got a while before he gets there.. so when that time comes, we'll recommend using his return line as a 2nd feed and run a new return line lol
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
