FS [SYD]: RB25DET Stock Bottom End, Head (or complete but dissembled) - the lot $400
Hai,
So most of you active SAU people might know, my Edward Lee's (Special Edition) Low KM motor finally exploded - which took out my turbo too. I had this big plan to rebuild it, make it a weapon but a few things in life got in the way so that's not going to happen anymore. Instead I am going to put another used motor in and call it a day.
Engine can come complete, although dissembled or parted as per the prices below. Water pump, timing kit are all under 3 years old and less than 20 000km (so can be easily reused for a cheap rebuild). Also has ARP non-2000 studs.
Cylinders 1 & 6 are cooked.. bores slightly scratched and head has some shrapnel marks.
$400 motor minus hotside, coldside, flywheel, coil packs, all ancillaries not included
OR
$200 head, cams, cam caps, cas, VCT, covers, valves. pretty much complete, no head studs
$200 bottom end, water pump, crank, timing belt, idler/tensioner, knock sensors, sump, blah blah., no water outlet
$100 full set of ARP non-2000 head stud/nuts/washers - torqued once only
Contact: Here or PM
Hope someone buys it, gives me some money to invest in a new used, non Edward Lee' SE motor lol
On 3/18/2017 at 7:04 PM, GeeDog said:
Hi Johnny,
Do you still have the head studs? Pardon my ignorance, but what is "non-2000"?
Just sold them on Friday :(
There is ARP and there's ARP 2000, which is much much stronger. Some people get confused between the two.
Will sell head/bottom end, everything as pictured except the coolant neck, electricals, coldside/hotside/coil packs for $300
BUMP
Take the head (complete with covers) and block (no sump, no pickup, no ancillaries, no water outlet) for $200
Pending pickup tomorrow - prospective buyer only needs a crank but picking up the entire motor lol
So you've got space for mine tomorrow then?
but it booorken lol
and... bottom end is sold..
Head Remaining!
  • Like 1
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
