Rb25 idles but won't rev
Hey guys. I'm a bit stumped on this one. I took my engine out in august to do a clutch and a few other things and I finally got it back in the car but now the car will start and idle but won't rev. Any throttle and it just sputters a bit. I've swapped tps, and cas to no avail. Checked the spark plugs. Boost leak tested and found some boost leaks but didn't fix the issue. Swapped out my ecu with a stock rb unit. When I first tried to start it the fuel pump didn't want to prime. It was something in the wiring by the ecu because I wiggled the wires and it came back.  Now I can jiggle the harness anywhere and not cause a change in how it runs. The car ran fine when I took it out.  Only thing I can figure is the wiring harness since it's kinda ghetto and there as the fuel pump issue. but it's acting like it has a massive boost leak or timing under throttle is way off.  Does anyone have ideas??? Thanks
https://www.sau.com.au/forums/topic/469520-rb25-idles-but-wont-rev/
17 minutes ago, Fredward said:
Would it be able to idle if they were on backwards?  They should be on right. It worked before and the lines are much different lengths so it would be hard to reverse without knowing it
Yes it would, i'll put my hand up and say I've done it. There is no harm in trying to swap them around and check if the problem goes away.
Just a stab in the dark here but had a similar issue with my lil brothers integra when we did a major service on it. Ended up being an earth cable connecting to the water thermostat housing to the chassis, so i recommend checking all the earths/ground wires are bolted up tight.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
