Newbie
Hi everyone,
Im Sammy and I'm from Queensland, Australia.
I am a car enthusiast and want to learn as much as possible.
I own a 1995 r33 GTST, which is pretty well stock at the moment apart from the fmic I finally had fitted just today. ??
I have joined this page so I can learn, ask for advice and make race car friends.
Please be nice and friendly ?
  • Like 3
https://www.sau.com.au/forums/topic/469547-newbie/
Thanks ?
Yeah sure, I've attached a picture.                               I will have to send an updated one in a couple of weeks, I've got some tein coilovers on their way and a set of wolf s1p, so I'm pretty excited for that ?
  • Like 1
https://www.sau.com.au/forums/topic/469547-newbie/#findComment-7816418
  • 1 month later...
Thank you [emoji4]
I'm happy with the looks for now but I'll eventually look into getting a tough looking body kit. Power wise though, I think about 350-400hp on 14psi should be enough for me.
Definitely happy to own one of the best cars ever [emoji1] I really know what true love feels like now haha
https://www.sau.com.au/forums/topic/469547-newbie/#findComment-7827021
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
