STOLEN: 1998 C34 Stagea (S2) - Black
This car is very dear to me and was stolen last night 09/02/2017 from South Road in Hampton East.
If you see it can you either report it to the cops or contact me directly on 0477 355 000
Reg ZXM-440
Thanks
https://www.sau.com.au/forums/topic/469552-stolen-1998-c34-stagea-s2-black/
UPDATE: I just spoke to the police, apparently it has been found in North Melboune with a busted ignition barrel and no other information. I'm guessing it was found by a parking inspector or a curious local. Will update when the inspector gets back to me and releases the car.
Thanks again for your help all. I'm very glad at the prospect of having it hack.
  • Like 5
Okay, it's finally home and some notable things to report are
  • missing ignition barrel made it shockingly obvious how easy older cars are to steal
  • things missing were a car charger, cheapo set of sockets and a vape (good quality stereo was left wtf)
  • it was obvious they went through every nook and cranny of storage space, even inside the spare tire tools
  • they removed the air filter panel which was in the boot
  • oil fine
  • coolant fine
  • tires fine
  • 1/4 tank of petrol left
  • flat battery
  • melted positive battery terminal
  • when jump started starter motor just clicks and battery terminal starts smoking
  • can push the car around in 5th and engine still turns over
so i think the next step is to find a column key lock set thing and call an auto elec to figure out what has gone wrong with the starter circuit
unless anyone has any ideas?
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
