Garage sale R34 and R33 GTR gear
Hi guys,
Got a whole heap of gear that I finally got around to taking photos of.
ALL items are located in Georges Hall, Sydney apart from the Lenso wheels.
Buyer pays postage. NO PaylPal.
Contact me via PM.
Prices are negotiable. Will knock a bit off for multiple items.
Item 1
HKS EVC 6 boost controller. Was used for approx 5000 kms. Worked perfectly when it came out. Decided to control boost through the ECU
$450
692F9068-EB12-42D0-A376-367F136388D3_zps
0E4A65E9-122B-4B33-B3C1-77C6F9BCF673_zps
Item 2
Sard 700 CC injectors. In the car for approx 7000 kms. Removed due to not being big enough.
102C1881-43B4-40C2-9F96-7AE6B2A0AD63_zps
A703BD5F-1802-42F0-A27F-47565CFCFF9D_zps
2226BF49-FF46-4082-82C2-C343BD053328_zps
Item 3
BNR34 Power FC L Jetro. NO HAND CONTROLLER! In the car for approx 7000 kms. $550
01D6FD19-1DBD-49AE-B0E2-EE2E062DCC98_zps
67730366-4DDF-40BE-8980-2998A98FDE71_zps
Item 4
Tomei Poncams Type B (260 @ 9.15) for BNR 34. In the car for approx 5000 kms. Comes in the original boxes. $450
316EF5DC-9A54-45D0-951F-4CA280D1ECB2_zps
B9FD2BC8-7C91-40EC-B2B9-07FC9025BE36_zps
78729048-3F41-435A-A970-F8AF34B9C4CD_zps
04140956-A305-414C-8789-4D35FF382630_zps
Item 5
Unigroup Engineering Intake cam. (260 @ 10.85) In the car for approx 4000 kms. Removed due to going V cam. $400
091604A9-4001-44ED-A48C-31CFF1A7CED4_zps
78366F83-CBAC-494C-AC2C-FFDF970D4E6A_zps
Item 6
Trust T4 Twin scroll RB26 manifold + single Trust gate. No cracks that I could see. Used for approx 7000 kms. $800
CDFD4823-0337-44F9-8F82-BF410F2550A8_zps
537D214E-7AA7-4DAB-9BF9-A86F5C7C7EA8_zps
0A3EEE63-189C-4493-92B7-B42A7D1D6398_zps
Item 7
HKS Hard pipe kit. Came off my 33 GTR. pipes and joiners are fine but personally I would change the clamps. $350
275D039A-3D7F-4343-8351-13B077D3ED7C_zps
Item 8
OEM coils to suit R32 and R33 GTR. Used for no more then 10,000 kms. I cant remember what they were like. $100
5ADB2BB8-AB47-427E-B3BA-45E8CDCC37DC_zps
Item 9
Splitfire coil packs to suit R32 and R33 GTR. Were working fine when removed and making 472 RWKW. $450. Coil bracket and loom NOT inlcuded!!!!
33631002-869C-4B6E-81CE-02DD68C8432F_zps
Item 10
Lenso D1R Wheels. 18 x 10.0 + 22. All in Very good condition. These are located in Forster NSW. Either pick up or organise your own courier! $900
45903E0C-7B50-4F0A-B38E-67A28FCC2F27_zps
82F6F818-C4BA-4FE5-BE05-FF505B3D7E4E_zps
96132295-4DB5-407B-9C76-EEBFD065F902_zps
Item 11
Link 7 Bar MAP sensor. Was working fine when removed. $100
2485866C-1174-4409-8733-CD0E2E90114F_zps
Item 12
OEM coil pack loom. Wouldnt be more then 10,000 kms old. Has been modified to suit a Morristech 6 channel ignitor which is not out of the car yet. $50 for loom. If you want the ignitor (which works VERY VERY well) we can sort something out.
Item 13
Greddy light weight water pump pulley. Stock size. $50
25577488-7977-4AB5-B988-85FCFE467D60_zps
Item 14
Valve springs, retainers and valves out of an RB26. I believe these are factory but cant confirm and unknown kms. $20
7F4A3C20-F8E5-41B8-B024-46CE70021D7D_zps
Item 15
Braided rear turbo oil feed line. Was perfect when the twins came off. $50
5AE6240C-B00D-446B-B324-475A83389F7F_zps
Item 16
RPM seat mounts. Only ever installed. Basically brand new.
FF5C88D5-E167-4F20-94EF-1FF0B814A29D_zps
Item 17
Z32 AFM's. On the car for approx 7000 kms. Were fine when removed. $250.
32C4CD20-95AD-4633-A5EE-0CA3940AFE92_zps
26DAF884-27C1-4628-843E-9B088244F659_zps
Item 18
Trust intake funnel twin into single.Filters included $150.
1FFC63F4-10B6-4689-85DD-C43B5B51E0A4_zps
EE9D71C2-EE2B-4B84-81DA-FCF68289D3F9_zps
Item 19
Momo steering wheel. $200
7E716E46-5158-414E-9498-A2B845772636_zps
Item 20.
Endless MX72 rear pads. Brand new. $180
998f6ebe-6598-4d48-93be-8c171c3a247b_zps
E4B20A8F-D89C-47D9-A6AB-EFA0FCAB4380_zps
Item 21.
K&N 1015 air filter. Never used. $60.
49D71AA6-B254-4378-A047-F2F5CF544416_zps
Item 22
K&N RU 5045 air filter. Never used. $130.
F3226643-0160-4FAD-A802-C94D52AB8F0A_zps
Item 23.
OEM BNR 34 cams. Unknown KMS. $50
https://www.sau.com.au/forums/topic/469586-garage-sale-r34-and-r33-gtr-gear/
Item 24.
Hypertune airbox to suit R33 GTR using a 6 boost manifold with BW EFR 8374 or 9180. Includes Titanium lobster back intake pipe. $550 without K&N 1015 filter or $610 with.
B921CC5F-5126-4D00-BD4A-364335966E60_zps
28C48F21-6CAB-4838-AE10-02452D0B6664_zps
Item 25.
Haltech EGT sensors and bungs (6 of). $520
FC1C1675-C431-4CE1-AC12-BEBBF63D8300_zps
FE6A7E0D-85D3-4D80-855B-7DE9DBF6794E_zps
1EC7A066-BA6E-4F0D-B98A-EA797144B689_zps
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
