MAD SKYLINE GARAGE CLEARANCE
Righto, long story short, sold my business and now I have a heap of parts to clear.
SUBSCRIBE for updates cause this post will be regularly updated.
Located in Fairfield NSW, small items can be posted, large items pick up preferable or can freight at a cost.
R34 Cabin Filters - To suit all R34 Models, BRAND NEW aftermarket - $35
R34 GT-R V-Spec Differential - $900
R33 GTS-T S2 Grille M spec - needs mesh (Supercheap Auto has meshes, cut to fit) - $80
R33 GTS/T Series 1 Passenger Side Headlight, good condition - $150
R33 GTS/T Coupe Boot Trims Set - $200
R33 GTS/T Series 2 Front Fog Lights/Indicators - $300
R32 GT-R Parcel Shelf - $100
More to come as I dig through my house.
https://www.sau.com.au/forums/topic/469595-mad-skyline-garage-clearance/
Sucks to not being able to edit top post. Heres more stuff:
R32:
R32 GTS-T/GT-R Rear Windscreen (2 available) - $350
R32 Coupe Door Trims Pair (Suede has been ripped out clean, can use as is or stick on yourself) - $200
R32 GT-R Interior Carpet, Good condition - $250
R32 GTS-T Interior Carpet, Good Condition - $150
R32 GT-R A-Pillar Trims Pair, very good condition - $250
R32 GT-R A-Pillar Trims Pair, 1 side has 3 or 4 broken clips - $150
R33:
R33 Engine Splash Tray (4 available) - $50
R33 GTS-T Full Boot Trim (2 available) - $200
R33 GTS-T/GT-R Boot Slam/Scuff Panel (2 available) - $40
R33 GTS-T M Spec Side Skirts in QM1 Polar White, good condition - $200
R33 GTS/T Midnight Purple Driver Side Guard - $100
R34:
R34 NISMO GT-T Automatic Cluster - $450 (GT-T Models only, may work with HICAS NA's but can't guarantee)
R34 Under engine splash Tray (3 available) - $50
R34 Sedan Side Skirt (LEFT ONLY) - $120
R34 OEM Fog Lights Pair - $200
C34 Stagea Bonnet, Series 2 in black - $250
One Size Fits Most:
New Gates Racing Timing Kit to suit all RB - 4 available - $200 ea.
RB26 Rocker Covers (no coilpack cover or timing cover, powedercoated wrinkle red) - $450 pair
RB25 Raceworks Fuel Rail, new, fitted and removed, never used - $120
RB25 ARP Head Studs 202-4301, NEW SEALED - $250
RB26 ARP Head Studs 202-4207, NEW UNSEALED BOX - $400
Mongoose M20S Alarm System (8 available) - $120
Genuine Nissan PCV Valve Grommet, suits all RB, VQ, SR, CA, VR etc. - $10
Genuine Nissan RB25DET M/T Speedo Gear Cog 32743-30P20 - $20
Genuine Nissan RB25DET M/T Gearbox Yoke Seat 32870-V5003 - $40
Genuine Nissan RB25DET R33 M/T Gearbox Yoke Bush (big type) 32861-01G00 - $20
Genuine Nissan RB25 R33 R34 Gearbox Yoke Bush (small type) 32861-H7301 -  $10
Genuine Nissan R33 R34 M/T Speedo Sensor 25010-21U00 - $200
Genuine Nissan Oil Pump Gasket RB Engines 15066-71L00 - $20
Pro-Torque Rear Main Seal, suits all RB - $35
Permaseal MLSR RB25 Head Gasket    S4413MLSR, new sealed - $250
On 14/03/2017 at 10:08 PM, viper2002 said:
Interested in R34 the under splash tray, do you have the one for the left wheel arch?
Will check and report back
22 hours ago, bawsr33 said:
R34 Cabin filters still for sale ?
yeah i have a heap of these
On 18/03/2017 at 7:57 PM, Exodus01 said:
i  need the stereo surround, its a dark blue color tho, all  the ones ive looked at have been lighter than what i need.. not sure if thats a series difference?
PM  a pic, i'm not aware of any being factory dark blue
I'm interested in the grille but can't seem to find any photos online... do you have a pic you can post up? Would be greatly appreciated
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
