E85 Fuel Consumption
1 hour ago, ActionDan said:
Well seems my car is about on par with what everyone else is seeing so fair enough. Will just have to run 98 for the longer cruises.
I'll just have to put a big fuel cell in the boot for some extra capacity lol
I used 50L on Saturday on 98 (150kms)....
Used a lot of 3rd gear (5-6K rpm up and over the hill and back)...
1 minute ago, ActionDan said:
Really? that's way more than I expected? That would be about what I used?
Yep - I filled it with Shell 98 on the way out  and less than 1/8th of a tank left.  Haven't refilled to verify- but given it takes a bit over 60L - 50L is what I would expect.
I was probably working harder in the rev range to keep up....
My 25det neo with ~380 kw to wheel
Driving from perth to albany, i got about 450 km to a tank, on the light, maybe could have squeezed another 10 or so ks out of it.
No narrowband or wideband hooked into ecu/tune.
I think thats pretty good haha.
Bigger turbo with generally softer response sub 3000rpm and less restrictive turbine can all contribute to fairly respectable fuel consumption in those conditions, for sure.  I agree with Jared, pretty good result when you think what it does when the taps are opened.
was suprised to see Albany had E85. was expecting you guys to bring 20 jerry can each but was suprisingly few there.Now just need it in Bunbury!!
Yeh was great having a town with 85 :)
Everyone knew that albany had 85 in prep for racewars.
( maybe the sponsorship from united helped make that possible ? )
But i think i get about ~300-350 on normal driving in perth.
Try and keep your tank floating around 40-50% range if you are doing a lot of road use, tends to have a good amount of the ethanol benefit but quite significantly better economy.
15 minutes ago, ActionDan said:
Interesting. I've just been putting straight United Race Blend in it, though I notice the sensor never reads above 80% despite my testing showing 90+ with the basic water/shake in tube tester.
Same, sensor tends to read around 79-80% (genuine gm continental). Only ever diluted it with 98 once, took ages to get back up to 79-80%
Yeah, if you run flex then it's really hard to get up to >80% if you aren't using straight ethanol - which means that it's also not too hard to keep it floating around 50-60% if you occasionally top up with a bit of petrol.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
