E85 Fuel Consumption
1 hour ago, ActionDan said:
Well seems my car is about on par with what everyone else is seeing so fair enough. Will just have to run 98 for the longer cruises.
I'll just have to put a big fuel cell in the boot for some extra capacity lol
I used 50L on Saturday on 98 (150kms)....
Used a lot of 3rd gear (5-6K rpm up and over the hill and back)...
1 minute ago, ActionDan said:
Really? that's way more than I expected? That would be about what I used?
Yep - I filled it with Shell 98 on the way out  and less than 1/8th of a tank left.  Haven't refilled to verify- but given it takes a bit over 60L - 50L is what I would expect.
I was probably working harder in the rev range to keep up....
My 25det neo with ~380 kw to wheel
Driving from perth to albany, i got about 450 km to a tank, on the light, maybe could have squeezed another 10 or so ks out of it.
No narrowband or wideband hooked into ecu/tune.
I think thats pretty good haha.
Bigger turbo with generally softer response sub 3000rpm and less restrictive turbine can all contribute to fairly respectable fuel consumption in those conditions, for sure.  I agree with Jared, pretty good result when you think what it does when the taps are opened.
was suprised to see Albany had E85. was expecting you guys to bring 20 jerry can each but was suprisingly few there.Now just need it in Bunbury!!
Yeh was great having a town with 85 :)
Everyone knew that albany had 85 in prep for racewars.
( maybe the sponsorship from united helped make that possible ? )
But i think i get about ~300-350 on normal driving in perth.
Try and keep your tank floating around 40-50% range if you are doing a lot of road use, tends to have a good amount of the ethanol benefit but quite significantly better economy.
15 minutes ago, ActionDan said:
Interesting. I've just been putting straight United Race Blend in it, though I notice the sensor never reads above 80% despite my testing showing 90+ with the basic water/shake in tube tester.
Same, sensor tends to read around 79-80% (genuine gm continental). Only ever diluted it with 98 once, took ages to get back up to 79-80%
Yeah, if you run flex then it's really hard to get up to >80% if you aren't using straight ethanol - which means that it's also not too hard to keep it floating around 50-60% if you occasionally top up with a bit of petrol.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
