500kw through a Catalytic Converter. am I dreaming?
Hey Guys,
EFR8374 is going on the gtr over the next few weeks, power will be in the 460-500kw @ wheels range. 3.5" exhaust all the way. is a 5" metal cat going to do it?
otherwise use a straight pipe for the track, and run a cat on the street?
alternative is this i guess:
Edited by burn4005
People use 100 cell cats which are probably not compliant anyway  so you could just use a fake cat. You usually have enough to do on a track day without swapping out your cat.
Plumb both gates after the cat.. so on cruise and stuff all the exhaust gasses go through the cat, when you crack the gates it just bypasses the cat.
Yes you might have some restriction but much better than having everything going into the cat(s).
This is what I've done to mine, but not at your power levels. 3.5" from turbo to cat, then after the cat it goes all 3".
Surprisingly it still was able to put out a basic 372kW, would have made more but I would have blown the stock motor much earlier on.
Can absolutely be done without too many problems, I run 450KW through a 100 cell cat at the moment (twin 3" dumps into a 100 cell cat on a 3.5" system with mufflers) without any issues.
A 4"+ front pipe from the dump to your cat would be a great idea and definitely recommended with the system necking down to a 3.5" system after the cat.
Doing it in 4" the whole way would flow better but will be significantly more expensive (decent quality, non "Alibaba special" mufflers cost $$$), possibly be a bit of a pain to package under the car and can be difficult to get to non cop baiting noise levels.
Edited by baron_von_bootsector
missed a plus
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
