Another lurker from England
Hello,
Not sure when I joined up here but have came here for a wander round. I bought an r33 gtr vspec in July last year and has took around 6 months to be put back on the road. Was missing an engine and gearbox when I got it and while a new engine was being built, I upgraded a couple of things. Its still on a run in map which is boring as I am limited to 4000rpm (link g4+ limit set at 5500rpm) but I noticed it had a misfire between 2-3000rpm under load so it is back at the garage 120 miles away having that and a few other things addressed.
Id never driven a skyline until the day I went to pick it up a few weeks ago so its all new to me. Did around 145 slow miles and have about 500 to go before the oils changed and the map tweaked with the limiter taken off. Be good when its ran in so I can familiarise myself with it and see what all the fuss is about.
Not sure its been worth all the hassle so far but haven't really had a chance to get to know it yet. People keep telling me it will be worth it in the end, I live in hope.
Bit of a long-winded hello but there you go,
Cheers
Edited by Jdm4life
https://www.sau.com.au/forums/topic/469627-another-lurker-from-england/
Rest assured it will all be worth it. I miss my R33 GTR to death.
Many GTR owners on here have gone through pain with their cars only to be rewarded at the end. Stick with it.
:welcome: to :sau:
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
