Hi all, I've got my blown RB25DET Neo stock bottom end for sale:
  • Cylinders 3, 5 and 6 have lost compression and it appears that the rings are fused, however still rotates
  • Two of the bores (5 and 6) are scratched deep enough to feel when you run your finger over the bore, there are less severe scratches on other cylinders too
  • When the engine went it first started pushing a lot of coolant and finally went up heaps in crank case pressure and started blowing oil and smoke from the breathers
  • There are some burn marks near the water galleries on the recently changed head gasket (Oct 2016, included with the engine) but we're not sure if these were there before, during or after the bottom end went
  • I am not 100% certain of the root cause of the engine failure and there may be other damage to the block besides the bores
This engine is off my 1998 R34 GTT sedan and was at 156,565km when pulled out, with the last 30,000 kms at around 275rwkw. The car was still movable when the engine was pulled but ran quite rough. Please let me know if you need any other information.
The engine is currently at my mechanic in Melbourne south east, pick up only.
What's included: Engine block, rotating assembly, head gasket, couple of other random gaskets. Possibly sump and oil pickup. I will keep the water pump.
Asking $150 but open to offers. Note I will need buyer's driver license number for the receipt. Absolutely no warranty other than this might make a very awkward coffee table :)
Thanks guys
  • Like 1
$100 if you come and pick it this weekend or next week, I need the space back.
I will even leave the sump and oil pick up on for you, so it should be good for those, crank, rods, engine mount brackets and perhaps the oil pump.
Neo goodness cheap cheap!
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
