33 minutes ago, 89CAL said:
If you want to live on the edge...... disconnect the actuators and CAREFULLY drive the car to see if it will get over 10psi. If it does then there is an issue with the boost control side
Good idea ill give that a go and see if I get over 10
22 hours ago, niZmO_Man said:
What gauge are you using?
autometer boost gauge plumbed into the line going to the map sensor.
still haven't tested driving without the wastegates connected as im unsure how to set that up. do I just remove the vacuum line to the actuator and just block it so I have the turbos there without any vacuum hoses going to it?
car originally had a boost tap installed where the stock solenoid goes, I removed that and put the solenoid back in expecting to have a bar of boost.
Edited by dave123456789
On 21 March 2017 at 7:36 PM, JDM33R said:
Just unplug and block the 2 lines from the solenoid and see if it spikes above 10psi. If not remove the rag from the intake blocking the intercooler.... like mine was emoji23.png haha
Hey mate I blocked the two lines going to the boost control solenoid and still only got 10psi
i noticed neither was really sucking hard at idle when I removed the bolts I use to block it.
if I blow in either one it make the idle note change.
where to from here? Pretty sure no rags in my intake lol
Either you have a boost leak or the actuators on the turbos aren't fully shutting.
I made up some 50mm and 80mm round nylon blocks with a tyre valve in one end, blocked off the intercooler pipes at both ends and Pumped it up to 20psi. You can definitely hear the leaks if you have any.
Cheers mate ill give that a shot.
  • 2 years later...
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
    • Hydro lifters not bleed up could be the ticking noise
    • You know the worst thing about acquiring more space for me? I tend to acquire more things to fill the space...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
