On 8/13/2020 at 3:51 PM, Unzipped Composites said:
I've seen 700rwhp through the stock lines with no signs of being out of flow.
If you put a pressure sensor on the rail it is interesting. Higher than desired base pressure that then drops back to where you want it then potentially drops off is the usual result
You may be able to set 3 bar with engine offf, but when running and pulling vacuum you differential fuel pressure is higher. Not the biggest deal but not great, and makes tuning for big injectors more of a pain.
  • Like 2
7 hours ago, BakemonoRicer said:
If you use a stock fuel system in this I will be so disappointed, basically getting the fuel to the engine for constant HP is critical
In 3rd gear I’ve chopped both an Audi RS5 and C63 AMG, I’m talking several car lengths
you need a fuel system for track work!!!! Put a flex sensor in it then you can run pump and E85!!! But getting a surge tank right is a black art I have all the secrets to get it right
It'll just get what's needed.
No point building a 1000hp fuel system for an engine that will never get there.
Surge tank isn't rocket science either at this power.
Sounds like I might need to budget for lines, I'm not keen on big base pressures.
No engine updates bu the daily got some new tech because Toyota have the most dated interiors ever. Went baller by spending $30 extra to buy a front camera too.
I'm not even sure the space shuttle has a front AND rear cam?!
  • Like 1
Eagerly awaiting future post complaining about fuel surge lol
Another option is to PWM your fuel pump in your surge tank and only fully drive them at 100% DC when you're on boost.
This would reduce the issue of having an undersized return line from your FPR back to tank.
I still think using both your stock lines as a return and running a new 8AN line from your surge to your fuel filter -> rail will solve the inherit issues and also be somewhat cost effective enough.
Another way is to run the FPR at the rear and use both the OEM return and feed as a twin feed to the front only. One small downside to this is your FPR "might" react a touch slower than what your manifold pressure is. If this lag translates to you actually noticing is anyone's guess.
I don't even have an aftermarket FPR currently lol plenty of work to do on fuel system when the time comes, it's an area I really know SFA about.
Current setup is a 2L surge with a 460lph Walbro and a 255lph lift pump in the tank with some braided lines here and there.
  • 3 months later...
Life been busy, engine builder been busy.
Head work nearing completion.
Basic shed nearing completion - maybe today they said, I opted out of being involved after the slab and ditched the original builder who was painful as f**k
Still have water, power and elec, slab clean-up and seal, get hoist etc before I can look at moving my stuff in and doing any real work, will be slow going as it's gonna be too hot for that shit in summer.
  • Like 2
3 hours ago, robbo_rb180 said:
Any more pics of the head work? I've started porting mine but won't going as far as yours has been done
Not really, he only gives me so much as there's some special sauce in the work he reckons. Dunno if it's relevant to your head or did you go P12 as well?
  • Like 1
no fancy ve head just the standard redtop still. Its hard to find info on what works with these heads so just cleaning up little and blending parts. I am aiming to make reliable 250kw (270kw on scramble) as don't want to do gearbox conversion.
For that power, what you're doing well be perfect I reckon.
  • Like 1
We'll see going to get into the standard exhaust manifold after I finish this off.
Have you picked a hoist yet for the shed? I've just ordered a HAPP70 will make working on cars so much better
Funny you mention HAPP, I was looking at HAPP40 or 60 I think it was, something like that.
1900-2000mm lift, clear floor, maybe 300mm extensions if Prado cannot be lifted above my head and still clear the safety (I think it will as Prado is under 1600 cabin height with racks at a guesstimate).
I went solar vents on mine, lots of hot days with no wind. Still too damn hot to work too hard today (shame I have to turn the car around after Bathurst yesterday to the rally next weekend...)
Wind is no issue where I am up on the hill, but from personal experience in my last place, the heat rising tends to make them turn a bit anyway which helps and having multiple 300mm holes in the roof allows the air to escape.
Last shed had a monument coloured roof with thermal break and whirly and it was fine for temps that I'd want to be working anyway. This one has thicker thermal break and a green roof and is higher so hoping it's a little better.
I have contemplated putting an evaporative cooler on this one, but whether it would help or just make it humid AF I dunno. After moving to refrigerative ducted in the house, I'd never go back lol
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
