Made some progress on the knuckle, have all the bushes out of one of them at least, bit of a learning curve in how to position the knuckle in the press and support it.
That angled arm was a pain the socket appeared to be going in squarely but appears to have jagged the edge in one spot so I will have to clean up that burr.
The noise it makes when the bush starts to give is a bit disconcerting lol I stood off to the side and had some safety glasses on.
Also as per my other thread, HFM rotors, good bad ugly?
HFM.Parts 324mm Front Two Piece Rotors Suits: 350Z Z33, Skyline V35
yeah I always use safety squints when using the press, and have a collection of big sockets and random bits to try and get the parts to sit the way they need to. They are a PITA but still easier than taking every job to a shop
I've never used HFM 2 part rotors, but have used both the DBA ones and ATTKD/D2/whatever ones and they have been fine. They never seem to quite deliver on being cheaper at replacement time to just do the ring though
Can't run the Attakd it seems, they don't do a 350z rotor which is a different hat height according to the specs i can find on 33R Vs 350Z rotors.
I'm inclined to give them a go, if they are shit I'll try something else. I've always liked a bit of R&D :)
Yeah the Z brembos definitely have a different offset for the disc to R/S stuff, but I'm sure JJ could hook you up with the right ones...hell they even had them for my F50 Cima
On 11/18/2021 at 8:24 AM, ActionDan said:
I'll ask, I don't mind giving the HFMs a try, but I also won't say no to Attkd as they have been tested ,ore from what I can see.
i've got the 324mm 2 piece rotors on mine with intima pads from dosepipe. no issues with them soo far!
  • Like 1
Nice, He was suggesting RS front and maybe SR or Type D rears, so I will likely end up with that sort of setup.
What rear rotors do you use?
Had been putting off the caliper welding as it made me a bit nervous, just thought stuff it last night and had a crack but didn't really prep enough so the bead came out a bit high/cold.
Been told to pre-heat this time and go higher on the amps. The back side I had started to tidy up to see how it looked, looked surprisingly decent to me, but I'm super amateur. No cracks in it this morning and it didn't come off when I hit it with a hammer (as I've seen them do on YT when they are too cold) but being a caliper bracker I will get myself a dremel type thing and grind the weld out and have another go with more heat in the gun and some pre-heating of the materials then post heating to reduce stresses.
When done my plan is to drop them in the ultrasonic for a clean up then a lick of paint.
All learning =\
  • Like 1
Spoke to a mate of mine who gave me some pointers, ground back, smoother out and went again.
Tested belting it with a hammer after grinding the weld down initially and it stayed put so atleast there was some penetration there previously.
Much happier this time, should clean up and paint up nicely.
  • Like 2
Made mistake of talking to Piggaz, then planets aligned and this came up cheap so it's on its way to the builder and we'll work out the rest when the engine gets back.
Builder is very happy lol
Anyone want a new VE oil pump or Aeroflow sump???
  • Like 2
  • Haha 1
I asked Prank to change the title lol
And before anyone says anything, this is actually nothing to do with Piggaz, I have been talking to my builder about this for ages but sitting on the fence, I just happened to be chatting to him when this pan came up cheap but it makes me feel good to blame my poor financial choices on somebody else ;)
Edited by ActionDan
  • Haha 3
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
