On 7/28/2022 at 5:14 PM, robbo_rb180 said:
thats the worst part waiting on parts.
Guessing something pretty decent too
Lol no not at all, I'm only excited because they're new and can finally have wheels and calipers on as my old 17s dont clear the calipers.
Still a budget bitch with budget wheels.
  • Like 1
On 7/28/2022 at 5:20 PM, robbo_rb180 said:
what brakes?
From a quick mock up I am able to get my evo brembo setup (evo 10 rotor) under my 17x9 +22 Te37
350z brembos on 2 piece HFM rotors.
Did not clear old banger Volk Emu shit offset 17x8s up front. No surprise there.
I sold the 17x9s as they were 4 stud.
Edited by ActionDan
  • Like 1
Juicy updates time.
Invested in a brass wire grinder disc and got to work stripping the paint off the LCAs then put the hoist to good use and rattle canned them satin black. In traditional fashion, I rushed/went a bit hard in some spots so there will be no close ups of the runs OK 😅
20220731_130718.thumb.jpg.6fcc6480712503958a5c6d9adb9c3693.jpg20220731_135519.thumb.jpg.30ab250ff560d2131ab741cb185941e2.jpg20220731_145041.thumb.jpg.6e6c3f72d60745a6579ccc92a49dacfb.jpg
Hunted around to find some new boots for the ball joint as 1 had split, the metal ring they come with is just a smidge big so it unseats when the ball joint moves full sweep, the old ones did this too. What have others done in this situation? The lip on the ball joint itself is not fantastic so I was thinking some fine gauge wire/safety wire to wrap/twist? I've also included a pic of the original boot.
Also, My wheels are arriving in the office today, but I'm working from home with a sick child sad reacts all all round.
I've also got a drill bit coming to do the front hubs so I can fit rotors and calipers properly.
Oh and here's another head pic update, Dale said he just had to tidy up above and below where the divider meets the roof/floor.
295945482_422338566624829_8364544382125964728_n.thumb.jpg.5f18156f8e192c3d295e4044da44715c.jpg
Edited by ActionDan
On 8/2/2022 at 10:06 AM, bcozican said:
killer wheels nearly bought those myself so many times
Thanks dude, I like them alot and being able yo go custom size is wicked, hopefully 0 offset fits 😅
On 8/2/2022 at 12:31 PM, robbo_rb180 said:
Nice, will look good on a white car.
Cheers, im thinking white or silver.
I'd really prefer silver because that's my jam but a white car will work better with the NCR logo and some vinyls I think.
  • Like 1
Check the fitment on this rice boi ❤️
Could have gotten away with +20 in the rear for sure but wanted square rims and needed +0 for that epic front coilover clearance - the +20s i tested barely had 2-3mm and +10 would only work with mild camber.
We'll see if we get away with those 50mm flares or wider guards - I have tubs for the front also.
Oh and my LCAs went in perfect and have *perfect* clearance for tools on the swaybar/castor nuts.
20220803_202306.thumb.jpg.efa391695ed1b4a301a9cc97350fdc00.jpgreceived_1438348636634397.thumb.jpeg.c71fad0fcbe9ce28e35a92212c1f818c.jpeg20220803_202422.thumb.jpg.1e1d1b0f15dd1ac5179a442d8d2f380e.jpg20220803_205348.thumb.jpg.e7b0677869f8674661eace3915f4c2d3.jpg20220803_202318.thumb.jpg.0e18ddce4848b3c7a6156b5fc9972e4c.jpgreceived_1756602028007065.thumb.jpeg.768fd423e84af370cbab832edae80c19.jpeg
  • Like 1
On 8/4/2022 at 11:50 AM, Duncan said:
fitment looks great, but they are super low profile tyres for track use
How bout now 😍
Just collected, the other 2 are going to a mate for test fitting.
This update only on SAU because forums are the best for build threads so there will always be some extra info/details etc here.
Bit of fiddling last night, wheels on up front, car movable again and back on hoist trying to work out if I actually need these tubs or not, having a hard time figuring it out (tubs are a lot of work and requires removal/change of lots of stuff in the bay too).
Dale reckons I need at least 75mm of travel so I can try and work back off that, a full lock to lock saw minor contact front and rear on the plastic guard liner/quarter panel/body kit but otherwise nothing major. That was all static though, not under compression.
I got them as I was told I would def need them for these size tyres so maybe I am underestimating how hard the car will lean on slicks.
Also, ordered gktech castor arm braces and the bar to make my own nismo power brace thing to help resist chassis movement. I am planning on having the cage come through the firewall to the shock towers also.
I'm waiting on ATP to come back to me as I assume I just have to put pressure on the tub and tack it in to place, but that profile looks very different! Added pic of his completed tubs for context.
Edited by ActionDan
It's very straightforward to check. Just take the springs off each corner, put the shocks/struts back in.  On the hoist, put the rear on a jack and move it through the full range up and down, just needs a mm or 2 for tyre deflection. At the front same deal except turn from lock to lock at say 5 points in the travel as well (top bottom middle and the in betweens).
With the GTR, the first place it hit was on the front bar at mid travel with wheels turned, because the caster pulls the wheel forward towards the bar compared to factory. Obviously you've dealt with the inner shoulder on control arm already, the other place is full lock, full compression hitting the inner guards
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
